instagram "footbraker67"
5 lug TO 8 lug conversion
I see alot of people go the other way but im wanting 8 lug wheels on all 4 corners. whats the easiest way to achieve this? I have a 2wd 67 longbed c10 and im wanting some heavier duty axles WITH disc brakes front and rear. Any ideas?
1967 lwb, bigwindow, factory air (converted to Vintage Air), custom option,4.5- 6 drop, TBI injected 355, 700r4, 5 lug, daily driver. 1967 Chevelle Malibu Drag car, 355, brodix heads and intake, powerglide, 10.82 @ 123 mph 1966 chevelle malibu, Street/strip, 355, spare parts from my other chevelle, 12.82 @104 mph 1968 lwb parts truck |
Re: 5 lug TO 8 lug conversion
I have disc brake spindles up front. Do 8lug rotors fit all spindles?
I think it will take a rear end swap and the front probably spindles and maybe a arms and tie rod ends.Most stuff on a 1 ton is bigger then anything else.
67-72 parts collector,…
![]() Join Date: Nov 2002
3/4-ton lower a-arms are different.
The steering components are different. Ball joints are different. You need a 71-87 3/4-ton donor parts (with or without the actual crossmember).
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-02-2015 at 01:20 PM. |
Will the crossmember from a 3/4 to bolt up to a 1/2 ton frame?
