RAT1968 '68 Cab/'71 Parts
What Do You Use To Polish This?
I seem to have a bunch of stuff that *claims* to polish aluminum.
But, try as I may with any of it, I can't get close to the nice luster that the stock grill had when it came back from the repairs/polisher when the build was going on. I have a hand-held buffer with pads, and I'd be good with taping off the grill and surrounding paintwork if I thought I could get a little more clean-up on it. I know it's silly. But sometimes I like stuff shiny. ![]() ![]() ![]() ![]() ![]()
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
Re: What Do You Use To Polish This?
Not sure you really can. It is anodized aluminum, not stainless. Buffing might improve it though, if you get the anodizing off.
It's bare metal now....The way it is in the second pic.....so, no anodizing is on there to screw up the polishing process. If I could figure out what works best to do the job, that is.
![]() Join Date: May 2014
I've always had great results with mothers metal polish.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
I've used stuff from here with good results.
If you use the right buffing compounds and polishes it comes out shiny. http://www.eastwood.com/autobody/buffing.html |
laying low
![]() Join Date: Mar 2001
Bill i used to use Happich semichrome polish on bout everything. Im not sure its still available. Most any metal polish will help it some .
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
I have tried polishing outer grills, no luck, so I have been scuffing with scotch brite then epoxy primer then shooting on silver paint (good quality ppg) they look good.
#8 | |
![]() Join Date: May 2010
Get it as smooth as you can with 1200 grit or finer wet/dry sandpaper first. Then use the Eastwood compounds. Use a bench buffer if you can take the grille off and manhandle it yourself well enough to avoid damage (or have a helper with steady hands). |
Uummm....maybe consider toothpaste? It is very mild and some brands have materials that are basically abrasive. Seen it done with impressive results. If you do this, try it on a test piece if possible first.
My other vehicle is unmanned.... |
#10 | |
![]() Join Date: Oct 2008
^^^^^ This. It's anodized. You need to remove it, using oven cleaner or sandpaper or whatever. THEN you buff it and the shine will come back BUT... you'll also have to continue to buff and maintain it to keep it shiny... |
![]() Join Date: May 2013
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
If you use oven cleaner do you just spray it on or do I need to scrub with a plastic brush?
1970 Long bed- Stress release "There are only two kinds of people that understand Marines: Marines and those who have met them in battle. Everyone else has a second-hand opinion." Unknown ![]() |
#13 | |
See Post #3. Now, it's about the "...buff and maintain". I like shiny. It was really shiny when I first installed it. I don't like shiny enough to remove it. What a PIA.....But, that WOULD be the right way to do it. I bought some White Diamond on line that I'll try when it comes. Then, maybe I'll get some Happich to have on the shelf, too. Good tips. Thanks, all.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 04-01-2015 at 04:52 PM. |
#14 |
C/10 junkie
Just use spit
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#15 |
#16 |
C/10 junkie
Haha. Ok this is no help but some assurance that it can be polished up nicely. The 70 I just had a highly polished grille. The po stated it was dented up prerty bad and he took it some good ole boy who straightened it and polished it and it looks great. Don't know what he did but sounds like maybe an old school method.
#17 |
Because you don't want to disassemble the grill unit, I have a suggestion. I purchased some 2" felt buffing pads from Harbor Freight and used them with my air angle dye grinder. Used Mothers metal polish. I restored all of the windshield and rear window trim with this system. The trim looks brand new. I realize that the window trim is stainless and the grill surround is aluminum but I suspect with the anodizing gone you should get good results. This assumes you have a compressor for the dye grinder. I have not tried it with an electric drill which spins more slowly but I am sure it would be better than hand rubbing. Pads will build up a residue as you work but there should be more than enough in the kit to finish the grill shell. Here is a link to the pads on Harbor Freight's web site:
http://www.harborfreight.com/2-inch-...kit-95993.html |
#18 |
![]() Join Date: Apr 2007
Progressively sand it with 1200,1500 and 2000. grab a can of Mothers and some rags and have at it! Cheers!
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
#19 |
i build and restore harleys here in Australia i use a product called "silvo" it comes in a blue and silver tin. basically you just paint it on let it dry then wipe it off with a dry cloth works an absolute treat on most chrome or alloy surfaces. im not sure if it available in the states but here you can get it at most grocery stores. try it it out if you can find it
#20 |
As always. When polishing anything follow the golden rule ... clean between the grits!
You won't get anywhere with 2,000 if your work piece and/or buffing wheel is contaminated with 1,200. My preference is Jeweler's rouge. Bars of varying grits really cheap. >> http://www.riogrande.com/Search/rouge |
#21 | |
forgot to mention the importance of this! Good call!
#22 |
I did wetsanding with 400, 600, 800, 1200, 2,000 and then 3,000 grit. When you think it looks good enough with any of the grits, do it two more times. Then do it again.
Then two steps of rouge with a drill and pads. The mothers polish applied by machine and then hand. I bet I have 8-12 hours into polishing mine, easy. I'm really good at it but I hate polishing stuff.
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
#23 |
Elbow grease
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
