Water Leak - Help
I've got a bizarre water leak.
I've included a few photos. It's near the back of the block, just under the intake/exhaust manifold. Anyone have any idea what is causing this leak? It leaks as soon as I put water in the radiator, with the engine NOT running. Any possibility this was some type of "casting plug" that popped out? |
![]() Join Date: May 2010
Re: Water Leak - Help
I can't see it to well in the picture but it is it a freeze plug that let go?
It only has original paint once |
#3 | |
Does anyone know if there is indeed a freeze plug on the 250's located in the area of the leak? The LEAK is located approx 6" behind the carb, and just below a bolt that secures the intake/exhaust manifolds. |
1961 crewcab
here is a pic of a bare 250:
but I suggest taking off the intake and exhaust and doing further investigating
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
1961 crewcab
it does look like there is a freeze plug in the head too
Okay...
I looked closer at the photo of the head, there are 3 freeze plugs and one of them is located exactly where the leak is coming from. I'll be pulling it apart next week, then I'll know for sure. |
Post Whore
![]() Join Date: Mar 2013
Judging by how much water is coming out I'm almost sure its a freeze plug. Crack or blown head gasket wouldn't let that much out. New freeze plugs are cheap.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
