Old 04-01-2015, 09:05 PM   #1
85burb
85burb's Avatar
One tire rubs after drop spindles.
We have a 67 c20 with factory springs that have to be sagging and drop spindles with disc brakes. The truck sits level side to side from ground to trim on wheel wells but only the passenger side tire rubs over bumps on the highway. The driver side clears fine. I *think* the front body is shifted towards the driver side 1/2-3/4 of a inch. Does not appear to have ever been wrecked. How can I push the front clip over? The tires are 235/70/16 they are a bit tall but I think if the body were centered they would clear. Any suggestions?
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 04-01-2015, 09:27 PM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: One tire rubs after drop spindles.
Shock is warn out and doesn't have the rebound anymore. I just added helper air bags into the front coils on my 71 and it made a hugh diferance in the scrubbing and ride!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
