lowest static drop in front
Hi guys was wondering what's the lowest you can go in the front end
on a 1968 chev truck and would the tubular controls give you a little more ground clearance any pictures would be great thank you |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: lowest static drop in front
Sent you a PM.
I would say 5/7 is easily streetable. Use the correct parts. Trim bumpstops. Relocate the shocks for better angles. Use QUALITY drop shocks. Bolt in c-notch. Use an adjustable track bar. (panhard bar)
