04-02-2015, 05:53 PM | #1 |
Need some help. Is this the wrong ball joint?
I can't get my spindle to sit down any further than this. It's a Mcgaughy 2.5" drop spindle and ridetech control arms. This doesn't look right to me.
04-02-2015, 05:56 PM | #2 |
Re: Need some help. Is this the wrong ball joint?
04-02-2015, 05:58 PM | #3 |
04-02-2015, 06:03 PM | #4 |
Looks normal to me.
As long as you can see the hole for the cotter pin to go thru the castle nut, you should be good. Plus, if that spindle fit down onto the A-arm, there would be no room for movement of the suspension. It will look more normal once you put the ball joint boot on. Are the ball joint part numbers the correct one's for that year of spindle? What part number/model year did McGaughy's say you needed?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White Last edited by 67 cst swb; 04-02-2015 at 06:26 PM. |
04-02-2015, 06:15 PM | #5 |
I had a similar issue and was using a '70 ball joint, but the spindles had been switched out to a '71 disk front. '70 & '71 are different ball joints, the '71s are skinner.
04-02-2015, 06:31 PM | #6 | |
04-02-2015, 06:33 PM | #7 | |
Look it over real good, there should be some numbers on it somewhere I would think. Are you able to see the cotter pin hole thru the top of the castle nut?
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
04-02-2015, 06:43 PM | #8 |
post the mcgoughy part # on here. i have the drop spindles for the 71-72 ball joints. ill tell you if i have the same part # as yours
67-70 uses 1 style ball joint in the lca`s 71-72 uses a skinnier one i believe 73 and up different lca ball joints too
1967custom |
04-02-2015, 07:10 PM | #9 |
I'll do that as soon as I get back home. Thanks
04-02-2015, 07:11 PM | #10 |
04-02-2015, 07:43 PM | #11 |
6072R & 6072L are the numbers on the spindles.
04-02-2015, 08:03 PM | #12 |
there has to be room for the boot... thats what that is. Slide the boot on before you go wrenching that tight
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
04-03-2015, 09:45 PM | #13 |
Here's another pic with the dust boot on. Probably a stupid question but Should it look as smashed as it is?
04-05-2015, 09:45 AM | #14 |
yes... it will bulge out once packed with grease.
