Old 04-02-2015, 06:51 PM   #1
Ricos54
Ricos54's Avatar
Remove or not to remove rain gutters
How many of you are removing the rain gutters above the door? Does it make a difference in the rain? I plan on driving mine everyday rain or shine and wondered if there is a advantage to the gutters or not. My doors are not fitting my cab very well and one of the things is the doors hit the gutters and thought about taking them out. I do really like them, but just not sure what to do with them.
Ricos54 is offline   Reply With Quote
Old 04-02-2015, 08:52 PM   #2
_Ogre
_Ogre's Avatar
Re: Remove or not to remove rain gutters
gutters actually hide a lot of flaws in the door fitment; gap/no gap, in/out, up/down, etc...
shop air compressor timer
Old 04-02-2015, 09:21 PM   #3
Ricos54
Ricos54's Avatar
I showed the body shop a picture of my cab with the doors on and he said I should have a 1/8" gap around the door so the paint does not rub off. Most places between my door and my cab don't come close to having a gap like that
Old 04-02-2015, 09:26 PM   #4
Kabwe
Certified Car Nut
Kabwe's Avatar
If you plan on driving your truck in the rain I would not remove them they do a pretty good job. I removed mine because my truck will be a fair weather friend.lol Also _Ogre is correct the drip rails do a pretty good job of hiding the gap that is between the door and roof like. I had to had metal to get it right. I love the look but if I were planning on driving my truck rain or shine I would not have done it.
Kabwe is offline   Reply With Quote
Old 04-02-2015, 09:41 PM   #5
mr48chev
mr48chev's Avatar
I have mine removed on my old cab and got water down my neck every time I got in or out of the truck in the rain. Worse though is water tends to roll around the edge of the top and in the space above the door top and get inside if it is really raining hard.
My ongoing truck projects:
Old 04-02-2015, 10:00 PM   #6
youngrodder
youngrodder's Avatar
I removed mine. I like how they turned out. To me they give the cab more of a hot rod look. I plan to leave them on my 53 Burb though.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 04-03-2015, 07:55 AM   #7
Speedbumpauto
Speedbumpauto's Avatar
I did a lot of work to the top on my truck, but left the gutters on. IMO, smoothing the top at factory ht. helps because it takes away from how tall the top is. Since my top is shorter, I dressed them dead straight with a sanding block and left them on. I like the result.
Speedbumpauto is offline   Reply With Quote
