04-03-2015, 02:47 AM | #1 |
Replacement rearend options
Curious what you guys are putting under your trucks as far as replacement rearends. Mine is in rough shape and looking to replace it.
04-03-2015, 08:27 AM | #2 |
Re: Replacement rearend options
You can usually find a good used axle on craigslist for pretty cheap. A direct bolt in replacement will be nice and easy. That or you can rebuild yours. Parts are readily available to go with direct replacement or stronger aftermarket. I see your in Hannibal MO, there is a guy on the Kansas City craigslist that usually has a few of these axles for sale. Now would be a good time to shop for a posi rear end or a change in gear ratio.
04-03-2015, 10:28 PM | #3 |
Good info thank you
04-03-2015, 10:41 PM | #4 |
If you can find one, A 9.5 inch 14 bolt 5 lug out of a 90s Chevy 454ss. They are strong 3.73 , and posi. It is the only 5 lug 14 bolt ever made that I know of.
04-03-2015, 10:44 PM | #5 |
Coleman's Army-Navy in Pennsylvania has GI Surplus, new GM axles on pallets, for $499, but they are 3.08:1, 10-Bolt and probably GovLoc differentials. Also shipping may be costly.
04-04-2015, 08:34 AM | #6 |
never had call to put anything in other than what came out. I suppose the day may come where these rears are that hard to find, and when that happens I'll adapt a later, more easy to find GM truck rear.
04-04-2015, 06:36 PM | #7 |
Off topic but I see you're from Hannibal. I'm from Palmyra so when I get my truck done we should meet up and show off our trucks.
1972 GMC K25 350 sm465 1969 GMC C15 350 th400 2009 Chevy Silverado 1500 |
04-04-2015, 06:47 PM | #8 |
I used my existing rear and had it rebuilt with all new parts. Bearings, seals, new ring and pinion added a limited slip differential plus new axles.
Went this route because I wanted all new parts in the rear assembly.
Steven 69 Chevy C10 Suburban 350 700R4 w/Disc brakes on all four corners 2017 50th Anniversary Camaro SS 2004 Chevy Impala LS 2016 Chevy Malibu LT |
