Old 04-03-2015, 07:48 AM   #1
IronCanine
I'm trying....
IronCanine's Avatar
Which one is factory correct?
Which single exhaust routing is factory correct? Above or below the crossmember? Are they both correct? 2wd vs. 4wd...Thanks for your help guys...
IronCanine is offline   Reply With Quote
Old 04-03-2015, 09:07 AM   #2
asolde
asolde's Avatar
Re: Which one is factory correct?
I am not sure but the one with it going above the cross member makes more sense to me.
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 04-03-2015, 10:43 AM   #3
69-72
69-72's Avatar
My 2wd 3/4 ton looks like the first picture
1969 Chevy Custom Camper 3/4 ton Rust free survivor
1972 Chevy Blazer CST 4x4 Almost Rust free survivor
1972 GMC Jimmy 2wd Undergoing surgery
69-72 is offline   Reply With Quote
Old 04-03-2015, 06:10 PM   #4
smbrouss70
smbrouss70's Avatar
Not sure if you have noticed or not, but you have a picture of a 2wd and a 4x4. The 2wd is correct under the crossmember, and the 4x4 is correct above the crossmember since it hangs down lower.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-03-2015, 11:26 PM   #5
IronCanine
I'm trying....
IronCanine's Avatar
...I did, that was my question. Those were the only two pics I have of Blazer crossover pipes that I think might actually be original. I am not sure. I thought they both might be correct. It makes sense to me too to go above the crossmember on my 4wd, but as you might imagine, it's hard to find pics of factory exhaust set ups.
Old 04-03-2015, 11:30 PM   #6
smbrouss70
smbrouss70's Avatar
My 2wd has sections of what I believe is the original exhast, but mine is a 4-speed for now, so it doesn't have the transmission crossmember back there. But it does pass underneath the trailing arm crossmember, so I would think that it would have gone underneath an automatic crossmember as well.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 04-03-2015, 11:34 PM   #7
IronCanine
I'm trying....
IronCanine's Avatar
Thanks for the feedback guys. We're not going to be bending tubes for a few days anyway. Unless someone chimes in to the contrary, I think we'll be copying pic 2.
Old 04-05-2015, 11:48 AM   #8
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Above the x-member for sure. Toss in a t-case skid plate while you are down there
Old 04-11-2015, 01:33 AM   #9
PDXk5
PDXk5's Avatar
That's my 72 4x4 in the photo. It's original exhaust routing. The pipes original to the muffler. My father-in-law was the original purchaser of the vehicle when it was new.
PDXk5 is offline   Reply With Quote
Old 04-11-2015, 07:19 AM   #10
IronCanine
I'm trying....
IronCanine's Avatar
Thanks for chiming in...I just wanted to confirm before we went to the exhaust shop since yours is literally the only original 4WD Blazer exhaust pics I've been able to come up with.
Old 04-24-2015, 07:36 PM   #11
1rippen6
I know this is late and it appears you found you answer put thought I would had this for future questions
1rippen6 is offline   Reply With Quote
Old 04-24-2015, 08:52 PM   #12
IronCanine
I'm trying....
IronCanine's Avatar
Brilliant Dwayne...is that the Assembly Manual?...gosh, I'm embarrassed that it did not even occur to me to look there. The manual is such a PITA as you know. Ours is tagged and stickie noted and marked to death just so we've got a fighting chance of finding what we're looking for in under 10 minutes....and since the last time I picked it up was to look at the shroud mounting(and we're far enough along as to generally not need it), it's just been put to the side. Thanks for adding this to the thread. It definitely helps.
Old 04-24-2015, 09:57 PM   #13
1rippen6
Got it from here
Old 04-24-2015, 10:01 PM   #14
IronCanine
I'm trying....
IronCanine's Avatar
Got it from here
That's awesome. Thanks. I guess I feel better that I didn't miss it in the AM...but it also makes me really want one of those.
Old 04-24-2015, 10:10 PM   #15
1rippen6
Really not a lot of pictures but picked it up on ebay for 45 plus shipping.
