04-03-2015, 04:03 PM | #1 |
'97 Astro Van wiring diagram - Where to start looking?
Bought a used auto steering column today at an auto jumble for a lot less than expected, it is an adjustable Automatic Chevy Astro van steering column, which included the ignition with three keys and all the plugs for its wiring at a sensible price.
I am fitting a new wiring loom and will need to splice the columns wiring to it. So looking for a copy of, or a pointer to an online copy of the wiring diagram of a 97 Astro Van Heavy bloody thing to cart over to the car after Martin had come all the way across the field to check out if he thought it could be grafted into my truck. Along with the new wiring loom it should be good if we can make it fit and work. Mouldy Airbag steering will have to go, then hopefully my original Moon style wheel can go on directly, or may need an adaptor. Will need some brackets to fit it, and being an adjustable means it could be a bit nicer to use. If anyone has fitted one of these to a 60-66 or other C10, then please let me know what to look out for and what the tricks are. Thanks as always for your help.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
04-03-2015, 04:56 PM | #2 |
Re: '97 Astro Van wiring diagram - Where to start looking?
04-03-2015, 05:02 PM | #3 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
I am pretty sure that any '97 GM column diagram will work for you.
The GM color coding is pretty standard, just google it! I did! I used that style column in my truck. If you go to page 20 of my build you can see how I mounted mine, but something has went haywire with the photos! They are super large, so maybe you can copy & paste them onto your computer & resize them to review...They were not like that when I originally posted them!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 Last edited by Modges'66; 04-03-2015 at 05:13 PM. |
04-04-2015, 02:05 AM | #4 | |
So not spending time on that. Thanks for posting up Modges'66, I looked at your thread and saved the pics and uploaded to my Phoyobucket, let's see if they do resize when I post up here.
04-04-2015, 05:24 AM | #5 |
Rian,
I have an old Camaro column here you're welcome too if it would help with the brackets etc. P. |
04-04-2015, 09:17 AM | #6 |
JUST FOR YOU WINSTON
Went over to Martin's early this morning as Nicola was off to visit her daughter in Buckinghamshire for a couple of days. He needed to move a load of stuff in his garage and shed, including getting his V8 and gearbox out the way, and then getting the straight six from his truck and it's gearbox out to the front of his carport for Über Cool, Andy to collect next weekend for his truck build. I took my new to me, steering wheel and column with to test fit/offer it up to his upside down cab to see if it will fit. So after the engines and sheds were sorted, we tried it out. My current Moon style wheels rim and boss are both 9" from the dash edges. The new one is 11" away, so I will need to do a bit of thinking around the best solution for form and function when I get to fitting it. While I was there, Martin ripped the airbag and it's ring and wiring out as well. When I got home I cleaned it all up, much improved. So now the steering wheel and it's airbag bits can get sold as I do not want a modern wheel on my truck, still need to figure out what splines the column has and see what adaptor I may have to fit to get a new steering wheel fitted. I personally like the older style stuff and love my Moon style that is deep dished and will be removed. One of the things we realised this morning was that the small plastic cover behind the light and indicator stalk is missing. Aaaaaaarrrgghhh !!!! This means I now need to find one from somewhere, and one would expect most columns to come with them fitted, so not many about to buy or scavenge. Anyway, if anyone knows where, or has one...... Please let me know. Next job today is to go build a rolling frame with some of the wheels I got this week and a box into which I can pack all the parts I plan to keep off the little Honda donor bike.
04-04-2015, 09:19 AM | #7 | |
I would like to take a look at that if it's OK with you. The new one is not a size fit, but pre made brackets are always the easiest way to go.
04-04-2015, 06:32 PM | #8 |
Grizz,
I was not able to locate the wiring diagram but this page has the missing cap for your column. http://www.steeringcolumnservices.com/ Blue666(2) |
