Rotella T off brand
For those that have Rural Kings near them. They have the Rural King version of Rotella T 15W40 on sale right now.....2 gallon jug for $12.99. Regular price is $17.99 which I still thought was pretty good for a 2 gallon jug. Around here the sale is good for another 30 days. It's made by the same company (Warren unilube) that makes the Coastal branded oil.
The regular Rotella T is on sale too right now. One gallon jug for $12.99 which is a dollar cheaper than I have found it anywhere else. |
Re: Rotella T off brand
I use rotella T, and I wish I could buy it for that! Here, a 5L jug (about 1-1/4 gallons) is $30.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
![]() Join Date: Jul 2000
Are you guys running diesel engines, or just looking for extra ZDDP? If so, I believe the new Rotella T has less than it used to have.
And regarding the cheap oil, I'd say you get what you pay for. So be wary.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! Last edited by MikeB; 04-05-2015 at 06:10 PM. |
At the body shop.
I run Rotella for the soot control, short trips and a double pumper. Got my 400 apart and looks new inside
" That didnt make it any newer " " Dont antique the equipment " |
Mike, I'm running two gas engines with flat tappet cams using 15w-40 rotella t. It's for the zddp. I think the grades other than 15w-40 have lower zddp. The cams are holding up fine, so I'm happy. And this oil is still cheaper then racing or special oils made for flat tappet cams.
Found this. Supposedly it's a quote from Shell:
There is approximately 1200 parts per million ZDDP in Rotella T 15W-40, which is 50% higher than is allowed in Starburst motor oils (API SN/GF-5). Thank you for your interest in Shell products. That 1200 ppm is apparently an average of P and Zn. Just for comparison, Mobil 1 "High Mileage" synthetic oils have 1000 ppm P/1100 ppm Zn, and their 15W50 weight has 1200/1300. Most Mobil 1 oils cost $27 for a 5 qt jug at Wal-Mart. It's what I use except for break-in. That's not to say Rotella T doesn't work fine. ![]()
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Rotella has a $5 rebate going on now, FYI. I use the T6 in my ATV's.
http://www.shell.com/rotella/promoti...promotion.html |
I run Rotella in everything that moves that I own. It's on sale at O'reilly's for 13.99 a gallon here...
Advance Auto also has it on sale for $13.99.
