Old 04-03-2015, 09:15 PM   #1
gramps77
how to adjust vent window with new seals
So I had Precision replace my vent seals and the passenger side is dead silent. Driver side, not so much. I can see that it doesn't seat as deeply in the seal and assume that's whats causing the issue. Is there a way to adjust them?
gramps77 is offline   Reply With Quote
Old 04-03-2015, 11:39 PM   #2
Titomars
Titomars's Avatar
Re: how to adjust vent window with new seals
odds are your vent latch is just worn out or bent slightly. Either problem is corrected by replacing the latch assembly.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 04-05-2015, 12:34 AM   #3
Swed-Chevy
Swed-Chevy's Avatar
My vent seals on my -83 are leaking a lot.The rubber have big cracks.Is it possible to replace the rubber without taking the window frame out ?
Chevrolet Cheyenne K2500HD 1992.350tbi.4L80E.
GMC Sierra Custom C1500 1983.
Oldsmobile Dynamic 88 -65.
Volvo V70 -02 and BMW 523i T -99.
Harley FXDF -08 and Harley FXDB -10.
Honda Dirtbike Dominator -97 and a couple of tractors.
Swed-Chevy is offline   Reply With Quote
Old 04-05-2015, 11:26 AM   #4
gramps77
Latch is new and not worn out. It does look as though it doesn't pull in enough though. Does the lower spring pivot adjust at all? Just wanted to ask before pulling the door panel all apart.
Old 04-05-2015, 11:52 AM   #5
Titomars
Titomars's Avatar
Well it was just a suggestion. 9 out 10 times that is the fix. a couple of other things you could check is the wrong seal used in the vent latch anchor to the glass. The is a couple of different thickness seals. Also the vent hinges might be worn.
Old 04-05-2015, 03:09 PM   #6
TKCR
TKCR's Avatar
Swed, it will have to come out.
Old 04-05-2015, 05:39 PM   #7
MikeB
MikeB's Avatar
And you might as well replace the door glass channel and window seals (fuzzies) while you have everything apart.
YouTube has several (maybe several hundred!) videos on how to do the job, some much better than others.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 04-05-2015, 06:06 PM   #8
TKCR
TKCR's Avatar
That's what I plan on doing with mine. They have all sorts of bundles for whatever need you have.
http://www.usa1industries.com/1973-1...therstrip-kit/
Old 04-05-2015, 11:24 PM   #9
MikeB
MikeB's Avatar
I'm in the process of doing mine using parts from ClassicParts.com. Good prices, fast shipping, and helpful phone support. I think these guys bought Chevy Duty Truck Parts, a catalog vendor from back in the day when you'd mail or phone-in an order.
Mike
Old 04-06-2015, 09:51 AM   #10
Swed-Chevy
Swed-Chevy's Avatar
Thanks for answer,looking for some better doors.The window seals and channels are worn out as well.
