Old 04-04-2015, 11:17 AM   #1
littlevictories
trouble logging trans diagnostics in HPT
I was having some weird TCC apply/release issues so I set up a config using the sensors and pids in the VCM scanner, but none of those parameters log during a scan.
I have a tune and a config here in this thread at HPT forums if you'd like a peek. 67-72 doesnt support loading .hpt or .cfg files here.
http://www.hptuners.com/forum/showth...ig-and-my-tune
Anyways. There's no codes or misfires logged to cause the TCC cycling issue. Bumping the line pressure seems to have solved it for the moment, but I'm more concerned that I can't log trans data as I'm planning a 4l80e swap here shortly.
anecdotally, my torque pro app quit seeing all the trans data too. I used to be able to watch trans temp, shift times and TCC slip…all that is gone but I'm not sure if that's due to switching phones or related to my HPT issues.
Doug
littlevictories is offline   Reply With Quote
Old 04-08-2015, 12:07 PM   #2
littlevictories
Re: trouble logging trans diagnostics in HPT
bump, still no trans data. all the wiring appears to be intact.
trans is functioning better, but i'd love to get some data to see if my problem is a wear issue as my trans warranty is coming up soon.
Old 04-08-2015, 12:54 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Do you still have any manual control over the trans via HPT? If you force lockup, does it go along with you, or does it do its own thing?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-08-2015, 01:20 PM   #4
littlevictories
Oh good question. I'll check today.
Old 04-08-2015, 11:36 PM   #5
littlevictories
yep I can command lock up in all gears. locks solid too, especially with the PWM turned off.
i must have my config all screwed up. if someone with HPT could take a peek that'd be neater than a skeeter's peter.
