Old 03-27-2002, 06:28 PM   #1
boilrman
70 Chevy 3/4t
Angry Rear U joint "U" bolts
I cant get the u bolts holding the rear u joint together to come out. I have hammered on them and pried between the u bolt and the joint itself. Seems like they are siezed inside. I need to change out the carrier bearing and figured I would change the other 3 joints as well while I have it out.
Would heat from a propane torch do me any good? I cant be down any longer than necessary with the truck as it is all I have to get around with while the wife is working. I wish the rear ones had the bracket and 2 studs like the front one does.
The ujoints look as if they have been changed once before, dont know for sure. But I have to get my carrier changed as it has about 1/2" play in it when I lift up on the driveshaft.
1971 Chevy 1/2t, 350 -- SOLD
1998 Yamaha V-Star 650
1970 Chevy 3/4t, I6(freshly rebuilt), 4 speed
Keokuk,IA
http://communities.msn.com/SchweringFamily/shoebox.msnw
MSN Messenger = boilrman
Find a job you love and you'll never have to work a day in your life.
1970 Chevy 3/4t, I6 (rebuilt), 4 speed
Kokomo,IN
boilrman is offline   Reply With Quote
