04-04-2015, 01:42 PM | #1 |
Headers 49 GMC
No traction over on the Advanced Design forum, so I thought I'd try here.
49 GMC with an 5.3L LS motor moved back in the firewall about 3". Using a 5spd and want to keep my pedals on the floor for that nostalgic look. Had 2010 LS Camaro shorties but they wouldn't clear the pedals. Between the motor mounts, steering and the pedals, it looks like I have to go over the frame and into the fender well Here's a shot at my initial attempt - These are plastic header modeling blocks from Icengineworks. Here's the second iteration of the design. The tube lengths are within about 10% of each other and nominal primary length is 29". At full lock, the front wheels clear the header by about 1.5" The plywood just keeps the tubes aligned. The header 'lego' kit is a little short on straight pieces so I have a gap at the collector Here's another shot- About to place an order for some stainless tubing - any comments or suggestions on the design before I do? |
04-04-2015, 05:36 PM | #2 |
Re: Headers 49 GMC
I did tight tuck shorty headers from sanderson for a 68-72 nova ls application. Used low mount gm organ donor motor mounts and clears anything you can think of in my 69 c10 5.3 ls. No frame perches in the way, no dirty dingo adapter mounts to get in the way of my gm low mount ac compressor mounting. Collector flange at about the trans/engine area pointing back and down at a 45 degree angle.
04-12-2015, 11:26 PM | #3 |
Re: Headers 49 GMC
Here are the Corvette headers we are using on a 46, the front section of the frame looks to be the same as the A D's
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
