Old 04-04-2015, 07:34 PM   #1
62 bigwindow
62 bigwindow's Avatar
Vertical drip rail ???
While doing some rust repair on a 65 I bought as a driver
Replaced all 4 cab supports, both inner and outer rockers and inner floors and toe kick panels. I noticed the vertical drip rail on drivers side of cab just in front of the door was rusted bad around the spot welds all the way down. I took one off a parts cab I have but wanted to ask... has anyone ever just taken them off and not replaced them? Looks kind of clean without them but was curious if their function out weighs the look...
62 bigwindow is offline   Reply With Quote
Old 04-04-2015, 08:14 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Vertical drip rail ???
I took the ones off my sub, and kinda like the look... I am curious too.
Old 04-04-2015, 10:49 PM   #3
Mikes66ChevyC10
Mikes66ChevyC10's Avatar
I also took mine off because of rust and I honestly don't think they are going back on. I like how it looks with out them.
1966 C10 Stepside swb
http://67-72chevytrucks.com/vboard/s...d.php?t=617778
Mikes66ChevyC10 is offline   Reply With Quote
Old 04-05-2015, 01:13 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I removed mine and ground the rivets that held it inplace. If your top drip rail gets filled up, the water runs down the door side. That vertical rail is supposed to prevent the water from rolling over into the kick panel or past the weather seal into the window channel.
If you have tight fitting doors and good (i.e. not 30 year old) weather seals, its less of a concern. If your truck never sees water, then its not a concern at all.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-29-2016, 04:13 PM   #5
Afirehawk1
Replacing mine and need a closeup of the rail near roofline or perhaps measurement. I forgot to measure before i removed the old ones. Thanks
Afirehawk1 is offline   Reply With Quote
