Old 04-04-2015, 08:22 PM   #1
jb9281
jb9281's Avatar
In cab gas tank?
Anybody know how to get rid of the gas smell inside the cab? I have no leaks, and a new gas tank rubber hose with new clamps. I did buy a new vented gas cap. Maybe I need an unvented gas cap. I have just finished a frame off restoration and I never drove the truck before the restoration, so I do not know if it smelled before. the orginal gas tank was in great shape, so I just repainted it.
jb9281 is offline   Reply With Quote
Old 04-04-2015, 08:38 PM   #2
jb9281
jb9281's Avatar
Re: In cab gas tank?
Forgot to tell this, it also give me a powerful "whoosh" whenever I remove the gas cap.
Old 04-04-2015, 08:39 PM   #3
jayoldschool
Moderator
New gasket on the sender.
jayoldschool is offline   Reply With Quote
Old 04-04-2015, 09:07 PM   #4
Indian113
Indian113's Avatar
Sounds like your vented cap isn't vented very well. Have you tried driving it without the cap tight? I could be wrong though I haven't conferred with my wife on this
Indian113 is offline   Reply With Quote
Old 04-04-2015, 11:50 PM   #5
BigSix
Mine did this too until I got a vented gas cap. Just order a new gas cap.
BigSix is offline   Reply With Quote
Old 04-05-2015, 09:09 AM   #6
bonehead
bonehead's Avatar
Make sure you have the correct cap, then if you have a new sender gasket and hose already, make sure you put sealant on the sender bolt threads. That's where mine was leaking and smelling. I sealed the sender screws and now its ok.
Good luck )bone(
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 04-05-2015, 06:12 PM   #7
63burban
Chevy addict
New vented cap, new filler hose is a good start
63burban is offline   Reply With Quote
Old 04-07-2015, 01:06 AM   #8
frankslagoon
Good luck )bone(
My screws are leaken also. I just picked up some fiber washers today but haven't put em on yet. what sealant did ya use. These in cab tanks are a real pain to get squared away.
frankslagoon is offline   Reply With Quote
Old 04-07-2015, 07:47 AM   #9
bonehead
bonehead's Avatar
I just used the 3m? white pipe thread sealant. You just need a dab on each screw thread. good luck
past trucks:
Old 04-07-2015, 02:08 PM   #10
frankslagoon
update on the screws: probably off thread here but I found two screws that did not have the factory washers on em. I put the pipe dope on anyway but there is suppose to be a fiber washer on them.
Old 04-07-2015, 02:13 PM   #11
1963c-10
1963c-10's Avatar
The folks above nailed it on the head. Make sure the rubber gasket between the tank and sender is good also. As mentioned above the filler neck hose probably needs replaced and vented cap.
Also not a bad idea to check the sending unit to under cab line to make sure its not leaking there.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-07-2015, 07:20 PM   #12
jb9281
jb9281's Avatar
I replaced the cap yesterday, now I do not get the pressure buildup as before and my shop does not stink of gas. Either I had a bad cap or it was not a vented cap. Thanks a lot for everybodys help.
Old 04-07-2015, 07:55 PM   #13
Indian113
Indian113's Avatar
The combined experience and knowledge on this Forum makes this just about the greatest place to visit.
Old 04-12-2015, 02:37 AM   #14
josephmichael09
I would definitely agree! I have the same issue and now I know exactly where to look for leaks.
josephmichael09 is offline   Reply With Quote
Old 04-12-2015, 01:16 PM   #15
vince1
I ordered a cap listed for the truck but it also pressurized like you describe so obviously not the right listing. Air could come in but not out. Over sitting for the winter and with the warm cold cycles it also sent gas past the carb and into the oil. I fixed it by drilling a vent hole just inside the rubber gasket.
vince1 is offline   Reply With Quote
Old 02-12-2016, 11:35 PM   #16
72chief
I have 72 chevy with factory cab fuel tank. I cannot fill the tank full due to making right turns gas comes out. ?! Any ideas?
72chief is offline   Reply With Quote
Old 02-13-2016, 01:39 AM   #17
Captainfab
60-66 Nut
Check and make sure your gas cap seals tightly to the filler neck. The aftermarket gas cap on my '68 slowly over a period of a couple years deteriorated, cracked and split causing this same issue. I just yesterday replaced it with a new cap, put 10 gallons of gas in this afternoon and no more gas shloshing out of the cap on right turns.
Old 02-22-2016, 01:52 PM   #18
schpeen
schpeen's Avatar
i too have a strong fuel smell in the cab if i roll my window down after driving for a little while the fumes get worse and worse. when i crack open the fuel cap lots of pressure releases.
I assumes my problem is coming from the new FiTech fuel injection we just added?
no smell coming from inside the cab i don't think do i need to get a more modern cap from a fuel injected vehicle?
The tank, hose, sending unit are all new by the way
1991 K5 Blazer 4x4 "9 ball"
2019 Chevy Silverado Trail Boss 4x4
2018 Chevy Colorado 2 door ZR2 4x4
1988 23' Mako Marine
2005 Harley Davidson Road King
schpeen is offline   Reply With Quote
Old 02-23-2016, 12:40 AM   #19
Captainfab
60-66 Nut
It sounds like you need a vented cap instead of a non-vented cap.
Old 02-23-2016, 01:45 AM   #20
schpeen
schpeen's Avatar
Thanks captain
Old 02-23-2016, 07:04 AM   #21
schpeen
schpeen's Avatar
[QUOTE=jb9281;7123697]I replaced the cap yesterday, now I do not get the pressure buildup as before and my shop does not stink of gas. Either I had a bad cap or it was not a vented cap. Thanks a lot for everybodys help.[/
Are you guys getting caps new or from the pull apart?
Old 02-28-2016, 08:02 PM   #22
schpeen
schpeen's Avatar
[quote=schpeen;7496300]
so i found my old vented gas cap and swapped it out which eliminated most of the fuel smell not all
think i want to go to the rear tank is it this one i found off a 69 camaro?
Description: Chevrolet Camaro Fuel Tank. Brand: Spectra Premium. Fits Years: 1969, 69. Fuel Tank -- With Filler Neck; (Tank Only - Does Not Include Fuel Pump); 39-3/8 In. x 20-7/8 In. x 7-3/4 In.; Lock Ring Kit Included - GM32B
More Fuel Tank Brands for 1969 Chevrolet Camaro
is this the tank that will swap out mine on a 65 short stepper?
Old 02-29-2016, 09:15 AM   #23
Ronw435
Ronw435's Avatar
I also had problems with getting the sending unit to seal. I went to an airport and got some B2 sealer, which is what they use to seal aircraft senders, and no more smell! Now if you ride with your window open and have a vented cap you might get a whiff every now and then, roll up window and nothing.
Ronw435 is offline   Reply With Quote
