04-04-2015, 08:54 PM | #1 |
Did our trucks come with pads between bed and frame?
I took the bed off my truck and there was nothing between the bed and frame.
I see where pads are available at Classic Chevy Truck Parts. Were they installed from the factory? Thanks |
04-04-2015, 10:03 PM | #2 |
Re: Did our trucks come with pads between bed and frame?
Never mind, found my answer.
04-05-2015, 11:30 AM | #3 |
The answer is no in case someone else is (or does) research this matter.
04-05-2015, 02:41 PM | #4 |
Yes, my bad, I should have explained. The Step side beds have the pads, not the fleet sides. The ones you see for sale are for stepsides and are 1/4" thick and would throw your bodylines off bad.
I am going to cut some pads about 1/16" thick out of some material. I think it will help in absorbing sounds. |
04-05-2015, 04:27 PM | #5 |
In my case, I installed some dense 1/4" thick pads at the rear of the frame rails and use about 3/4" thick rubber snubbers at the front of the frame rails because I have a dump bed conversion and the bed bounces around when driving and makes a lot of noise. The trim lines on the side of the bed does not line up the the corresponding line on the doors and front fenders, so I am leaving all of the trim off to lessen the visual impact.
04-05-2015, 07:04 PM | #6 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 04-05-2015 at 07:13 PM. |
04-05-2015, 07:12 PM | #7 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-05-2015, 07:41 PM | #8 |
04-06-2015, 09:03 AM | #9 |
yeller
I ran 1/8" thick rubber washers between my bed and frame on my 73 fleetside, the local Ace Hardware has them in all shapes and sizes.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
04-06-2015, 09:10 AM | #10 |
04-06-2015, 01:41 PM | #11 |
yeller
Get a washer that is as wide as the frame...so you have more coverage for movement
