Old 04-04-2015, 11:05 PM   #1
Iceburgh
Iceburgh's Avatar
LS harness question....help please
I have most everything wired. I have a few plugs with no place to go.
I switched from the factory front accessories and went with a small condensed package for space. That said the aleternator, AC compressor and everything else out front has been switched.
Can I just terminate these plugs?
Will it start and run if I do?
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 04-04-2015, 11:54 PM   #2
oldman3
oldman3's Avatar
Re: LS harness question....help please
Beyond my knowledge...Jim
oldman3 is offline   Reply With Quote
Old 04-05-2015, 12:51 AM   #3
clinebarger
What "front runner" system do you have? Most have POS 1-wire marine/industrial alternators?
What compressor, A/C system do you have?
clinebarger is offline   Reply With Quote
Old 04-05-2015, 09:52 AM   #4
Iceburgh
Iceburgh's Avatar
Sanden SD-7 compressor and the alt is a 140 amp 3 wire.
Getting all of that to work is not a problem through the stand alone Haywire system..... just not sure if any of that feeds through or needed with the PCM
1953 suburban build
