Old 04-05-2015, 01:56 AM   #1
1moretoy
If you have bags and a c-notch please step inside
A few questions for you guys. I'm running slam ss7 bags a c-notch and 2" lowering blocks that I made. I plan on running 20" wheels as well.
1. when aired up to ride height how much space is between the axle housing and the bump stop in the notch? I'm thinking I will be around 5" or so, does this seem right?
2. I'm not sure what to do with my drive line angle. If the gap is 5" for drive height the yoke on the rear end is pointed up and the output shaft on the trans is pointing down. Isn't it supposed to be the opposite? A friend of mine has some 2" blocks that are tapered from his lifted truck I could use. Not sure what to do here. I attached a couple pictures to help with what I'm trying to describe. The third picture is the degree of the yoke(pointing up) if I'm at the 5" mark for ride height. Please let me know what you think.
Thank you,
1moretoy is offline   Reply With Quote
Old 04-05-2015, 04:14 AM   #2
tinydb84
tinydb84's Avatar
Re: If you have bags and a c-notch please step inside
1. 5 inches should be plenty.
2. Trans down and rear end up is normal. It looks like you have about 6 degrees up which is a bit more than you want but is probably okay. Does your trans point down 6 degrees as well?
David
Instagram: myfabguy
Old 04-05-2015, 10:19 AM   #3
1moretoy
Do I just stick the angle finder on the tail shaft to figure out the degree?
Old 04-05-2015, 02:55 PM   #4
tinydb84
tinydb84's Avatar
Yes. It should be within a degree or so. Maybe someone else will jump in but I would like it closer to 3-4 degrees.
David
Instagram: myfabguy
Old 04-05-2015, 05:40 PM   #5
1moretoy
Ok I disconnected the drive shaft and the tail shaft is pointing down about 6.5°-7°. And with the rear axle 5" before it hits the bump stop on the c-notch the yoke is pointing up between 5.5° and 6°. You think I will be ok ? Thanks for the help.
Old 04-05-2015, 08:31 PM   #6
tinydb84
tinydb84's Avatar
You're pretty close. I'd put a small spacer (probably 1/4" or less) under the trans to get it to 5 degrees. When you accelerate your rear end will turn upward a degree or two.
David
Instagram: myfabguy
Old 04-06-2015, 05:25 PM   #7
1moretoy
Thank you for the help tiny.
Old 04-08-2015, 02:48 PM   #8
1moretoy
Anyone else?
Old 04-11-2015, 02:27 PM   #9
DLW
Kind of a more simplistic view but what your looking for is the centerline A and centerline C are the same angle or really close to each other, and not pointed directly at each other.
DLW is offline   Reply With Quote
Old 04-11-2015, 04:20 PM   #10
mongoose
mongoose's Avatar
are truck arms really that flimsy? I know leafs do that.. but though arms would get rid of that problem.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 04-11-2015, 04:37 PM   #11
1moretoy
I thought the same thing.
Old 04-11-2015, 06:15 PM   #12
MySons68C20
MySons68C20's Avatar
Thanks DLW, that is the most helpful illustration I've seen showing the angle relationships.
MySons68C20 is offline   Reply With Quote
Old 04-11-2015, 10:54 PM   #13
tinydb84
tinydb84's Avatar
I could be wrong. Nice thing about a shim is that you could remove it if it does cause vibrations.
David
Instagram: myfabguy
Old 04-12-2015, 06:26 PM   #14
SCOTI
SCOTI's Avatar
The pinion shouldn't rotate/change much w/truck arms during acceleration. The rotating up issue is usually w/leaf spring set-ups.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
