New Guy
Sort of, Joined Several years ago. I have a 1985 C10 that I bought 14 years ago for my first truck. It's been on the back burner and I'm back at it. My dad actually bought an '85 about 10 years before I did and still have his too. I will try to post some pics asap.
I'm looking for a few things that I want to do and change with the truck. A few years ago I did a 5/7" drop using a DJM kit, spindles, coils, rear axle flip kit. The truck sits on 22x9" Gun Metal Coys. I have an aluminum 5.3 with LS2 heads, tbss intake, F-body oilpan/pump, MS4 cam, ls7 lifters and a few other goodies. For the trans I'm putting in a 4L80e with a stall from Circle D. Should be gettting the motor and trans in soon. I am wanting a fun, but quick driver. I want to ditch the leaf springs and go with a 4 link with coil overs. What is the route to take? I have been looking at QA1's and I'm not sure which set I would like. I would like them to be adjustable. I'm not doing a budget build, build I'm not going to spend several thousand dollars on the rear end either. I have seen several 4 link kits that are on ebay, and I have considered piecing the kit with QA1's myself. Also looking at different front sway bars. Anyone have any input on belltech or Hellwig sway bars? Thanks in advance! |
#2 | |
Re: New Guy
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Re: New Guy
Take a look at http://pbfab.com/shop/73-87-rear-dropmember-coilovers
Re: New Guy
Sorry about the structure of the text! Honestly, I try to do that. I'm on my Iphone and it's difficult for me to type and make it easier to read. I also have a 100000% complete '98 LS1/4L60e that has less then 10k miles on it, been sitting in my shop for ten years haha. I may use it first, get the swap done, then throw the 5.3/4L80e in.
I got the L33, LS2 heads (243's), tbss intake, 102mm throttle body DBC, and some other parts for pretty much free. I had a '03 GMC and I have bought several LS motors and sold some of it off. It isn't worth it to me to pay a ridiculous price for a 6.0. With that, people are paying crazy money for LS1 engines, so I plan on getting rid of it. I think the 5.3 in the end, will do everything the LS1 does or more. |
#5 | |
Re: New Guy
I guess what I want the truck for would help with the information that I am looking for. I'm not wanting a race truck. I don't want to take all the glass out and put in a cage. But if I want to take it to the track twice a year, I would like it to get traction! More importantly, I want the truck pretty much slammed height wise and not beat the crap out of me. The better the ride quality the better with it being slammed, not body dropped and laying frame. If I wanted all of that, I would go with bags. I think the single adjustable coil overs will be what I am wanting for the truck. When looking at Wilwood brakes, what are the different options available for our trucks using the same 5x5 bolt pattern? Also, part numbers would be greatly appreciated. I have searched and searched but I'm still not gaining much information. What weight rating and type of coil over should I be looking for? Am I correct that the heigher weight rated shocks will be stiffer? |
Re: New Guy
Re: New Guy
I love this truck, wondering how you got that patina to perfect of the pass side.
Rest In Peace:Mikhail {Mickey Rooney} Alpha 2/5/13 Omega 7/22/14 10:28AM I love you tremendously and outragiously Superpuppi Thai Ridgeback...The most intelligent dog known to me. Don't mess with my truck, my momma or my money...not necessarily in that order. ©Stand for something or fall for anything. [LIST][*]'98 Bourbon St. Brawl ©2010
![]() Join Date: Mar 2013
Re: New Guy
Wheel and tire combo looks great. Do you mind sharing the backspace and tire specs?
Re: New Guy
The surface rust just ate through the primered spots. 22x9" Coy Wheels, tires in the front are 265/35r22 rear are 305/40r22. I don't remember the backspacing I ordered. I saw on the website that they only offer 5" and 5.5". It seems like they offered me a custom backspacing and one was 6.5" for the front and the rear were 5.5". I'll have to measure and see. The 305/40r22 is a little bit too tall. It's difficult matching tread with a staggered setup. A 265/30r22 & 305/30r22 would be perfect to me.
#10 | |
Re: New Guy
Re: New Guy
I have found some but I'm not sure what route to take. I have seen several options. I also read up on traingulated 4 links and 4 bar setups with/without anti sway bars. From what I read, a 4 link has the lower bars parralel to the surface, and top bars at an angle. Also, the 4 link is stiff around corners and will actually lift the outside wheel off the ground in turns and an anti sway bar would make that worse. A 4 bar setup has all 4 bars parallel to the surface and does well with an anti sway bar. If I'm wrong, please correct me.
As far as tires, I would prefer to keep the 265/35r22 in the front, however I want a 12" wide tire in the rear and matching tread. There are only so many options. I have seen a 305/40r22 but nothing smaller in height with a 305mm width. I have also seen 315/25r22. That is a little wider then 12", but the sidewall is to short. |
