![]() Join Date: Apr 2012
Headers for 1952 Chevy PU - Need Advice
I have a 1952 Chevy PU with original A frame. I put a Heidts MII cross member in. I needing a pair of headers, any recommendations? I believe, I need Block Hugger Headers if I'm correct.
![]() Join Date: Jul 2012
Re: Headers for 1952 Chevy PU - Need Advice
Assuming for a small block Chevy, block huggers, rams horn style manifolds, and copies of the rams horn style should work. I am sure there are others that would work too.
Yes, I have a Small Block Chevy.
We used block huggers on a 52 with a big block. I did have to do some creative notching on the frame but it wasn't much. I think there are some pictures on my build thread.
Bernie |
![]() Join Date: Mar 2011
Use HPC headers for my build, no problems with clearance etc. Here's a couple pics....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Jim, looks like you moved your column to the left just a bit?
Doug, yes I did and down about 1" to 1-1/2"...Jim
Thanks for your responses, I really like the look of the block hugger headers so I'm leaning towards those.
Jim, are you running a small block? I'm thinking Bernie had to notch the frame because his BB and you're running a small block?? I've looked at the build links of everyone who responded..Nice work! If I can do 1/2 as good as you guys I'll be pleased. |
Yes, mine is a 350 small block...Jim
Thanks 52, glad we could help a bit. Jim is very talented builder and reviewing his build threads is well worth your time for learning, plus a lot of fun. I've been learning a lot here!
I've been perusing his thread for the most part of the day
Great history on your truck! Hopefully you will put up a build thread when you get started.
Have fun! |
#13 |
AD and 52, thanks to both of you for the compliments, glad I can be of help to anyone doing a build...Jim
#14 |
Will do, as soon as I can find some pics and a little time I'll start my own build thread. As a new member of the site I look forward to posting with you guys in the future.
