problem after drop spindel install.
So I just go around to putting a set of drop spindels on my 80 c20. I've done drop spindels on 4 s10s a isuzu 2 dakotas and a nissan hardbody. Every one I put on I was able to drive to get an alignment when I got the time. This truck the front end is pulling so bad it's crazy. Tires look to be going out like the left is turning left and right is turning right with the steering wheel strait. It also now has slight positive camber. I know your suposed to get an alignment after any suspention mods but I drove it around the block and literally could see the wear on the tires. They were almost to hot to touch on the inside edge. Anyone else ever experienced this? I'm really hoping that an alignment will fix it but I may have to tow it there.
Plays with trucks
Re: problem after drop spindel install.
I've never had one that bad.You might want to try to measure/set/adjust the toe-in. That usually is the worst for wear on the tires. The ones I've done (all C-10s) I put the shims back in the way I took them out and they were close enough to drive to the shop.
Gary My Dad's Old Truck 1985 ![]() Last edited by 85gmcguy; 04-05-2015 at 09:26 PM. |
Is it possible to get them on the wrong side?
67-72 parts collector,…
![]() Join Date: Nov 2002
What brand are your spindles?
BellTech spindles on my Nissan Hardbody had to have 1/4" chopped off the tie rod threads so the thing could actually ~be~ aligned. Said so right in the instructions. BellTech spindles on my C10 were not a problem at all. Well, other than clearancing to fit 15's.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
The spindles I'm told were chassis tech but they actually look good as far as casting and machining. I checked them against my old ones and they don't look bent or anything I'm guessing that maybe they have the tie rod mounts out further than stock.
![]() Join Date: Jul 2000
I have seen at least one set of dropped spindles (on a 55 Chevy car) that required several turns of the toe-in adjuster sleeves to get the toe-in back to where it should be.
Google "DIY toe-in" or "Set toe-in at home" and you get lots of hits on how to get it close without a gauge.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
On C20/30's, drop spindles change the position of the outer tie-rod from what I remember because the steering arm changes (moves the seating position from bottom to top). This will have a greater impact on alignment vs the other models you previously had experience with.
A simple adjustment of the toe is what you need. Use a tape measure from a common groove in the tire tread on both front side & rear side of the tires. Adjust the toe until it's about even. That will get you to the alignment shop.
Thanks ill look it up and try to get them at least close before I drive it to the shop. I'm going to take a loop off the front coil since I have to get it aligned anyway just to get it sitting a bit lower.
![]() Join Date: Jul 2014
dragin91 - Be sure and let the rest of us C20 guys, contemplating this drop, know how it all works out in the end! Snap a couple of photos if you can...
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
Will do spent today putting drop shackles and hangers on the rear now I just need to find a place to find new u bolts. And I should note my truck is a 80 c20 but has factory one ton suspension. Probably because it's a camper special. And a tip for removing the hanger rivets. Use a plasma cutter! Much easier than last time I did it with a grinder lol.
Chassis tech is another name for airbagit.com i would be scared to run anything they touch.
