04-05-2015, 09:24 PM | #1 |
Rally Wheel Width
04-05-2015, 09:46 PM | #2 |
laying low
Re: Rally Wheel Width
The truck rallys came in 7 and 8" widths. The 6 1/2" were available on the vans. The width is measured between the rim beads.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
04-05-2015, 09:55 PM | #3 |
That's what I figured. I measured with the tire on the rim, air out laying flat on the floor with a straight edge across the to and I got 9" with a 4 1/2 inch backspace. So I'm thinking a 10" wheel with a 5" backspace.
04-05-2015, 10:13 PM | #4 |
laying low
That'll do it. And with 295/50 or 275/60 the 10's look *****n .
04-05-2015, 10:34 PM | #5 |
Does a 265/70 stretch over a 10?
04-05-2015, 11:05 PM | #6 | |
Also, on a GM 8" rally, you will see 15x8 JJ stamped somewhere on the wheel. This should help:
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
04-06-2015, 12:25 PM | #7 |
Thanks Mike!
04-06-2015, 12:28 PM | #8 |
275 / 60 is what is on my Son's 95
04-06-2015, 01:21 PM | #9 | |
275/60's would get my vote. They look nice & square on a 10" wheel vs pinched slightly & the height remains close to OE.
04-07-2015, 10:25 PM | #10 |
Back in the day, I had 275/60s on all 4 corners of an 81 LWB with 8" rallys. The tires were probably a bit wide for the wheels, but they looked OK and the truck would grip the road like crazy in corners.
Turns out BFG recommends 7.5" to 9.5" wheels. Go here and click on the "Specs" tab below the tire pictures. http://www.tirerack.com/tires/tires....omCompare1=yes
