04-05-2015, 10:19 PM | #1 |
Temperature gauge question
What are you guys using for your stock gauge sending units?
Thanks in advance. |
04-06-2015, 11:12 AM | #2 |
Re: Temperature gauge question
These guys can hook you up...
https://www.lectriclimited.com/ The stock temp gauge in neither my 69 Chevelle nor my 64 C10 worked correctly until I got the proper sending units from Lectric Limited. Now they both work perfectly. A tad pricey, but worth it. |
04-06-2015, 08:39 PM | #3 |
Thanks man!
04-06-2015, 09:36 PM | #4 | |
I didnt see it on LMC either.... |
04-07-2015, 11:17 AM | #5 |
I think this is what you need, from Lectric Limited's catalog...
"01513321 TEMPERATURE SENDING UNIT, -original 1/2 x 14 N.P.T.F.-, with factory gauges (correct resistance and connection, produces accurate gauge display)" I went to this section of their catalog... "1965 GM CHEVROLET TRUCK/PICK-UP/SUBURBAN/BLAZER" I believe if you call them they will verify that 01513321 is the correct temp sender for a 65 GMC with factory gauges. |
04-07-2015, 03:42 PM | #6 |
I called and that's the one!
Thanks again Mike. |
02-05-2016, 11:19 PM | #7 |
But Found Her 25yrs Later!
Saved for reference
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
