Question about TH350 in 72 C-10
I am restoring a 72 C-10 short wheelbase stepside that I purchased without a engine or transmission. The SPID states the truck was orig. built with a TH-350 automatic & 350 smallblock. Was the trans in shortbeds the shortail or longtail version of the TH-350 in original trucks. Also, would like to know if either could be used with diff. length driveshafts, made to fit. The rear is a 12bolt (non-posi) if that makes a difference.
Thanks for your help guys ! |
laying low
![]() Join Date: Mar 2001
Re: Question about TH350 in 72 C-10
If i'm not mistaken the t350 has a 9 inch tail housing in the short wheel base application with the one piece driveshaft and 2wd.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Thanks for your reply Boog....I know a later model trans can also be made to work, but I like the availabilty of the Th-350....simple and not too expensive to have rebuilt.
Anyone in the North Jersey area have a trans shop recomendation along with approx. cost for a stock bench rebuild ?? |
![]() Join Date: Oct 2014
Not in your area, I'm Indianapolis In area but my 350 is getting overhauled right now and estimate is $450/500 with new converter. This might give you some idea of cost.
I'm in SW Conn and just had mine done privately for $700. The two shops I called were 1000-1100$$
Thanks for your replies guys. I am going to call around for some local estimates. About 15 years ago I had a th-350 from a camaro done (bench job) for $350 with a new converter, so around $500 seems like quite a good price in 2015.
$675 out here in AZ.
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
