Old 04-06-2015, 02:24 PM   #1
Vortech
Vortech's Avatar
Road draft tube plumbing
Need clarification on road draft tube plumbing. Currently, my road draft tube is connected to my air cleaner with what appears to bve an inline PCV valve. I also have a tube from my oil filler connected to the base of my carburetor. The oil filler cap appears to be vented. Is this correct?
Vortech is offline   Reply With Quote
Old 04-06-2015, 03:54 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Road draft tube plumbing
In the original configuration, the road draft hole in the back of the block behind the manifold would have had a hard pipe installed that hung down on the passenger side of the bellhousing. As the vehicle moved down the draft a draft on the bottom of the tube would suck the fumes out of the crankcase. It wasn't a very efficient system.
Your current setup appears to be installed backwards. A PCV (Positive Crankcase Ventilation) valve will not function correctly hooked up to the air cleaner. It must be connected to full manifold vacuum.
If you have the hose adapter in the road draft tube opening now, it should be routed to a PCV valve and connected either directly into the intake manifold (usually behind the carburetor) or directly to the base of the carb at a full manifold port. This is the only way the crankcase will be properly ventilated.
The valve cover can have either an open breather, or a breather with a tube on the side connecting to the air cleaner. You can actually have breathers on both valve covers if desired. The purpose of the breather(s) is to allow fresh air into the engine, while the PCV pulls the fumes out. A breather connected to the base of the carb without a PCV installed will function as a massive vacuum leak and the engine will idle crappy.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-06-2015, 04:13 PM   #3
Figuarus
Figuarus's Avatar
you should have a line with PCV from either the back of the block (for V8's) or the side of the block on the passenger side (for I6's) and you also need a source for intake. That would be the crankcase intake.
I have fixed my Road draft tube conversion.
Here's the thread: http://67-72chevytrucks.com/vboard/s...d.php?t=645971
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 04-06-2015, 06:02 PM   #4
Vortech
Vortech's Avatar
Thanks for the responses. So sounds like I need to run the tube from the rear of the engine to the base of the carb with a PCV in line. Do i then run the tube from the oil filler to the air cleaner?
Old 04-06-2015, 06:10 PM   #5
Vortech
Vortech's Avatar
some photos[ATTACH][ATTACH][ATTACH]Name:  WP_20150406_15_04_06_Pro.jpg
Size:  37.3 KB[/ATTACH][/ATTACH][/ATTACH]
Old 04-06-2015, 06:58 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Yes that is correct. Back of engine to PCV then on to the base of the carb. The breather on the oil fill tube doesn't really need to go anywhere. It just needs to be a "breather" cap, not a sealed cap. This is where fresh air will enter the engine.
Old 04-06-2015, 09:17 PM   #7
HumphreyMurdoch
HumphreyMurdoch's Avatar
I've got the same style engine in my truck.
Here's what I did, put a grommet and the PCV valve in the hole in the back of the block and will run the hose to the back of the Carb with a hose barb. Then use a breather cap on the fill tube. The original 2bbl carb has a pipe thread where the original PCV valve screwed in, 1/8"? I think?
Grommet: Dorman/Help #42323
PCV Valve: Standard V158
[IMG][/IMG]
[IMG][/IMG]
Sorry about the enormous pictures. Just really trying to get my point across, I guess.
Hope this helps.
'62 C10 LWB fleet side.
283 w/ a T5
HumphreyMurdoch is offline   Reply With Quote
Old 04-07-2015, 04:26 PM   #8
bhc41051
bhc41051's Avatar
I ran into the same thing with my P.O.S the Exxon Valdez. I'm pretty sure you need the piece inside the galley to make everything work.
bhc41051 is offline   Reply With Quote
Old 04-07-2015, 08:29 PM   #9
Vortech
Vortech's Avatar
so I found this picture: mine was plumbed as a "closed positive ventilation System" without the flame arrestor and with a vented cap. I'm going to go the top route and use the grommet and PCV.
Old 04-07-2015, 10:57 PM   #10
AcampoDave
AcampoDave's Avatar
I did the pvc conversion too. (Thanks Figarus for the thread) and am enjoying not having "motor stink" wafting thru my vents via the cowel. I never knew pvc hose was a special type until I tried using the wrong kind and saw it collapse from the suction.
AcampoDave is offline   Reply With Quote
Old 04-12-2015, 03:05 PM   #11
Vortech
Vortech's Avatar
Ok, I didn't want to remove the distributor to use the pcv grommet suggested above. I did find this one part number 46023.
Old 04-12-2015, 03:06 PM   #12
Vortech
Vortech's Avatar
Part
Old 04-12-2015, 03:08 PM   #13
Vortech
Vortech's Avatar
I used pcv 158 in conjunction with adapter
Old 04-12-2015, 03:12 PM   #14
Vortech
Vortech's Avatar
These are the parts I was able to eliminate. Thanks to everyone on this board for their help.
Old 04-13-2015, 03:51 PM   #15
canadian_diesel1964
So is it best to leave the can in the galley even when you retro fit with a PCV at the back?
canadian_diesel1964 is offline   Reply With Quote
Old 04-13-2015, 03:54 PM   #16
geezer#99
geezer#99's Avatar
Yes!!
It's there as an oil seperator.
Keeps the oil in the motor and only allows the crankcase fumes to flow thru.
geezer#99 is online now   Reply With Quote
Old 04-13-2015, 03:56 PM   #17
canadian_diesel1964
Thank you! I'll take it off to clean only then replace
