Old 04-06-2015, 09:56 PM   #1
LeesTruk
instrument cluster swap question
For my LS swap into my '80 C10, I'll be using an instrument cluster from a '90 Suburban with the electric speedometer. I've found the pin outs' for the '90 and '80 clusters, so I know what pins to move around and/or reconnect. Do I have to use the temp/oil pressure sensors from the '90 Suburban or can I use the sensors from the '80 C10? The '90 sensors are three pin sensors, whereas the '80 sensors are single blade. Thanks
Lee
LeesTruk is offline   Reply With Quote
Old 04-07-2015, 08:55 PM   #2
656mx
Re: instrument cluster swap question
I used single wire sensors in my 87 crew ls with 90 burb cluster. Its been a couple years but i don't remember there being any major wiring differences between the two besides some repining.
656mx is offline   Reply With Quote
Old 04-08-2015, 05:44 AM   #3
LeesTruk
Thanks. Wasn't sure if the resistance values had changed
Lee
Old 05-17-2015, 07:42 PM   #4
High ho silverado
High ho silverado's Avatar
For the temp sender use the 98-02 firebird sender, it has 3 wires, get the pigtails too, not hard to find, take the two wires from the factory harness plug and put them in the 3 wire plug then use the 3rd wire and connect it to your green factory truck harness wire and the factory gauge is ohmed right.
Dan G
Lift it, fat chicks cant jump!
83 Chevy shortbed 4x4: 6.0 ls powered
97 Chevy 3/4 ton ex cab 454: work horse
00 Chevy camaro: daily driver
83 Chevy 3/4 ton: dads old rig
High ho silverado is offline   Reply With Quote
Old 05-17-2015, 08:26 PM   #5
LeesTruk
I ended up drilling/tapping the pass. side head for a stock sending unit. Thanks
