IN LINERS ASSEMBLE! 292/250\230 brain picking time!
Need to see mechanical throttle linkage setups for a 292 preferably that's running and offey 4 barrel intake and edlbrock 600 carb.(That's you tj) cable linkage is okay but I really would like to stick with mechanical. Also anyone know what this implies? I get its a power pak. but is that the company's way of saying "heavy duty" because the 292 was the bigger motor of the 3. Any helps appreciated.
Well that didn't go as planned. 1965 k20 buikd thread: http://67-72chevytrucks.com/vboard/s...=628346&page=6 |
Moderator
![]() ![]() Join Date: Aug 2011
Re: IN LINERS ASSEMBLE! 292/250\230 brain picking time!
Here is an old build I did in the early 90's, I think you can get the linkages from Clifford now days for a 4 barrel.
I was in October 1993 Street Rodder magazine with this one ![]()
Very nice man. Is that a 216?
Moderator
A 1953 235ci, tricky huh?
#5 | |
Post Whore
![]() Join Date: Mar 2013
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
Post Whore
And I forgot...since your gonna be running the offy with carb will be mounted different than mine. Ok....make things hard on me. lol
Yea the carb mounts sideways:/ you can see in the pics where the linkage is at on the carb... Oh well any ideas would be awesome I might use cable. But last one I used was on a 51 gmc and it was HORRIBLE. So unless I can find a cable setup that is cheap ish and works as smooth as mechanical linkage I am so open ears.
Nice to see the original color being used. Looks great man!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Post Whore
I used Lokar...though not to Cheap per say...the system works wonderfully. Easy to install and is great quality. I'd do a cable setup, you'll be alot happier instead of growling and groaning trying to figure out a mechanical linkage. Engine looks killer dude!
Post Whore
Here's the Lokar part numbers:
Throttle Pedal: BAG-6149 Throttle cable: TC-1000U Carb Mount: SRK-4000 These are all the fancy brushed aluminum parts. You can go to Lokar.com to see them. If you have an Autozone or Baxter in your area I'd get the parts from them. Oh yeah...you'll need a spacer for the throttle pedal. If you have a 1/4 or 1/2 inch thick piece of metal, cut it into a square and drill two holes and yer good. The pedal has threaded holes.
Thanks tj. I'll look into it. I just remember when I last drove the cable linkage I could feel the cable drag in the guide tube and it was horrible. Maybe it was a cheap one but I'll look into it. As for the motor I'm now looking for an aluminum thermostat housing and goose neck. Along with a high torque 292 decal for the valve cover. At least until I find a 235 cover so I can put on my new head I'm building with roller rockers .
Thanks man. I stoked by how it turned out.
#13 | |
Post Whore
#14 |
Post Whore
Here's a link to the exact same one I bought. http://www.ebay.com/itm/Polished-230...item2c9979e020
#15 |
Ooooo. shinny
#16 |
Post Whore
#17 |
Moderator
You could probably find one cheaper than this but make it work with your stock pedal linkage. Thats a tough one being sideways and all:
http://www.ebay.com/itm/New-race-car...item3c9aa1fc04
#18 |
Thanks rocknrod. I might be able to just machine something like that. Looks simple enough. Buuuut buying it may be way easier.
#19 |
Post Whore
#20 |
WOW thanks tj! That made my life so much simpler my linkage is closer to the fire wall. But I think I know how I am going to fix it up. I'll use cable but I may just have to make my own custom Mount. Thanks for taking the time to do that
#21 |
Post Whore
No problem! Be sure to post pictures! lol
#22 |
Will do I may get to it this weekend. Not sure
#23 |
If you turn your carb around so the primaries are closer to the valve cover it'll be easier to set up a cable or your old rod linkage. The way you have it now the cable needs to bend over the valve cover. And your stock choke cable will reach too!
#24 |
Post Whore
Matt, Geezer just brought up a great point...turn your carb with the primaries toward the valve cover instead of away from the valve cover. That's how I was imagining your carb in my video. I didn't noticed your carb was the other way. lol That'll make hooking up linkage a whole lot easier in itself.
#25 |
[QUOTE=TJ's Chevy;7126286]Matt, Geezer just brought up a great point...turn your carb with the primaries toward the valve cover instead of away from the valve cover. That's how I was imagining your carb in my video. I didn't noticed your carb was the other way. lol That'll make hooking up linkage a whole lot easier in itsel
I can see what you and geezer mean. I was so excited to just see the motor all together I just tossed the carb on. ![]()
