Extended cab s10 for '54?
I was trying to find an s10 frame to use for our 1954 Chevy pickup and came across an extended cab short box. Will that work or does it need to be a regular cab long box?
Re: Extended cab s10 for '54?
If you have a long bed it is the exact frame you need. If you have a short bed than it can be used. The way the S10 frame is built there are 3 pieces. The front section is the same for all of them then the frame rails slide inside of it. You will have to do cut the factory welds, slide the rear section out, cut off 8" from the rear rails, slide the rear back in, and weld it back together.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#3 | |
![]() Join Date: May 2007
this is true except there is only 5" difference between a long bed s10 and an ext cab s10, if you cut off 8" it will be a little short. 108.3" Shortbed 117.9" Longbed 122.9" Extended Cab here is the splice ![]()
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
thanks for the info... very helpful
