![]() Join Date: Jun 2014
Rear Bumper
I bought a rear sport bumper for my 67 stepper off of Craigslist and things aren't lining up right. The brackets are from Brothers trucking. I have to raise the bumper to get the middle bracket holes to line up. When I raise it up it interferes with the tail lights.
What do you guys think? Does the bumper look like a stepside bumper or could it be a fleet side bumper? ![]() ![]() ![]() ![]() |
Re: Rear Bumper
You do realize those are not the stock tail lights nor location right?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: Rear Bumper
Is it possible your custom tail lights are to low?
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
#4 | |
Re: Rear Bumper
Re: Rear Bumper
Anyone else have any ideas? Comparing SS Tim picture to my bumper the outside mounting holes sit out wider maybe 3-4" out.
Re: Rear Bumper
Looks like someone removed a lot of material behind the bumper.
![]() Join Date: Sep 2007
Re: Rear Bumper
taillights do need to be higher so you can raise the bumper. do you have the shields also?
1967custom |
Re: Rear Bumper
I have run Model A lights but I put them on after the bumper to gauge best height. i wanted them low but not crowding the bumper. IIRC, they were right about where the reverse lights mount.
The pictures do make it appear that your bumper outer holes sit wider than those on the picture Tim showed. It looks like your bumper is rolled out at the bottom/tilted forward a bit at the top.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 04-08-2015 at 10:04 AM. |
#9 | |
Still plays with trucks
Re: Rear Bumper
I used square body bumper brackets on my 69 C10 stepside but had to do some trimming on them so the bumper sat at the angle and position I wanted as well as fit the holes in the frame. You may have to do the same.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
Re: Rear Bumper
Looks more like it is the picture than the bumper. Your shot with a wide angle lens, up close has curved the tailgate up at the ends and the bumper down at the ends. Plus the bumper being propped up and not level with the truck appears to be exagerating the outer bolt hole location.
![]() Join Date: Dec 1999
Re: Rear Bumper
Re: Rear Bumper
You do have a step side bumper but I can not figure out what is going on with it. Looking down at the top of your bumper brackets does each one have a hole on top were you would bolt the dust shields?
#13 |
Re: Rear Bumper
I think your main bracket arms are on upside down. I think you would have to take the rh side and flip it and use it on the lh side, and visa versa. When the main arms are installed correctly there will be holes on the top side for gravel shields, inc. the arms that angle outward.
#14 |
Re: Rear Bumper
Could be the photo, but looking at picture #1 & #4, looks like the bumper is bent down on the right side starting at the license plate relief. Could be an optical illusion also?
#15 | ||
Re: Rear Bumper
Did you have to drill different holes? Can you post a pic of how the lights are mounted? Thanks |
#16 | ||
Re: Rear Bumper
#17 |
Re: Rear Bumper
Your tail lights are setting lower than Sierramtns, his are even with the tailgate...
