Old 04-07-2015, 01:54 AM   #1
Devillusion
Devillusion's Avatar
59 Apache short fleet cummins project
Well, collection has started on parts and supplies for the build. Nothing much will happen for a while yet. Will take some time I would presume to find everything I need....but stranger things have happened.
So far...dragged home the 59, bought a 67 GM 1 ton 2wd frame, swapped in an 84 front suspension (getting swapped to SRW from DRW), everything is bolted in. Next step is to lay the cab and front clip on the chassis to figure out body mounts. Looks like it should work out to be a super simple swap. This will accomodate the 95 P pump 12V cummins/NV4500 trans, and D80 rear quite well. Will shorten frame when cab and clip are mounted. Hump in frame looks like it should give me no issues what so ever. Hoping the body will drop low over the frame.
Plan is to make this an all around toy.....no real use other than to have fun and cruise in. Mileage is not my main concern....useable power is.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 04-07-2015, 01:57 AM   #2
Devillusion
Re: 59 Apache short fleet cummins project
Forgot to mention that I picked bought a parts truck....59 long box fleet 2wd, same colour etc, just a long box brother. Bought from pictures only, looks to be in decent condition, and an excellent parts truck. Should be home in the next week or two.
1970 Chevelle
Old 07-01-2015, 12:42 PM   #3
Patience
Look forward to seeing your progress... I'm planning on putting a 12v in mine as well!
Patience is offline   Reply With Quote
