Old 04-07-2015, 03:36 AM   #1
Paul Y
How to centre rear wheels? Would this work?
Morning all!
Apologies for the lack of activity but... well yeah...that...
Anyway, currently planning the first in the major changes to Woody, one of which is to upgrade the suspension front and rear.
So, whilst I have the big spanners out, how have you gone about centring the rear wheels in the arch?
The fact they are not central really bugs me!
Does flipping the control arm mount push the wheels back and if so is it enough?
Or... My though is to machine a spacer to fit between the control arm mount and the cross member if flipping the bracket is not enough.
Also... How far does it have to go back by?
Appreciate a few questions but want to reduce the down time as much as possible so if I need to make or acquire parts want to do so whilst still mobile.
Thanks,
P.
Paul Y is offline   Reply With Quote
Old 04-07-2015, 06:27 AM   #2
PGSigns
PGSigns's Avatar
Re: How to centre rear wheels? Would this work?
Working this issue on my 65. Here is my plan so far. Going to use an aftermarket trailing arm crossmember to move the entire setup back about 2" when I install it (looking at porterbuilt). Use the shock relocators like No Limit has that move them to the outside. That gets them out of the way for the exhaust. Use a panhard bar from Porterbuilt that bolts to the frame on the drivers side so it can be shifted aft as well. Bag mounts and notch placed as needed. Will require a new drive shaft but I don't have one now so not an issue.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-07-2015, 07:05 AM   #3
Paul Y
Thanks Jimmy.
I have the No Limit adjustable Panhard rod, will be relocating the shocks to the outside of the frame and am also using Robs front and rear anti roll bars (sway bars).
Have a notch kit I am throwing in there as well for future stuff.
Not really in the market for an after-market cross member.
Having said that if I need to move the cross member back 2" to center the wheels then can that not be done by moving the original back?
Has anybody flipped the control arm mounts and measured the how far back this pushes the wheels?
All very interesting.
P.
Old 04-07-2015, 02:17 PM   #4
frankslagoon
When we lower the trks with different springs the rear end swings forward in the wheel well. I think the guys are usen a spacer between the control arms and the rearend. that would set the rear end up straight off the control arms instead of swinging it forward. does that make sense ?
frankslagoon is offline   Reply With Quote
Old 04-08-2015, 06:33 AM   #5
PGSigns
PGSigns's Avatar
Lowering the truck will move the rear a tad bit back as the trailing arms get closer to 0 angle in the arc of travel. Adding blocks moves it a bit forward. You don't gain much of anything by flipping the brackets on the trailing arm cross member except an improvement in pinion angle. You can move the stock trailing arm cross member back and redrill it. The big reason for me going to an aftermarket cross member is the added space to run the exhaust. You can mod the stock cross member but with all the other work done to the truck its just a nice looking piece to add to what I have.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 04-08-2015, 12:51 PM   #6
DLW
I too went with the PB cross member and trailing arms. The nice thing about the cross member is it gives you several different mounting points to choose to correct suspension geometry and pinion angle. The arms themselves have adjustable ends to center the rear.
DLW is offline   Reply With Quote
Old 04-08-2015, 03:31 PM   #7
vin63
It's Better With Nitro
vin63's Avatar
Yep, when you lower the rear of the truck, the trailing arm geometry of the arch pulls the axle centerline forward. This is what I did to address the aesthetics. Since I am running a 31" tall tire, I sectioned the area in front of the wheel opening and stretched it 3.5 inches forward. The vertical reference line above the wheel opening was the original axle centerline.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-08-2015, 05:39 PM   #8
The Rocknrod
Moderator
The Rocknrod's Avatar
I just looked at those, Nice. Did you have to move the spring or shock mounts?
Also it says:
"Note:
This crossmember uses a late model carrier bearing (PN HB88107A), and will not work with the factory carriers bearing. The placement of the carrier bearing mount, is moved forward, and a stock driveshaft will NOT work. It would require it being modified to work with the new carrier bearing location."
Carrier Bearing? What does that mean? Is that the driveshaft support bearing?
Old 04-08-2015, 11:38 PM   #9
Slow Build
Slow Build's Avatar
P.
The notch kit is probably set up for the stock rear axle location. Just something to think about.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 04-09-2015, 02:40 AM   #10
Paul Y
Good point!
Will be looking to st t work in a few weekends time, still pondering if just putting 2" spacers between the crossmember and brackets will achieve what i am looking for.
P.
Old 04-09-2015, 10:43 AM   #11
chevy_mike
Never Ending Projects
chevy_mike's Avatar
If you move the mounts back 2", everything behind it will not line up correctly. Spring mounts and panhard bar will all be in a bind, if they fit at all. Even the wheel wells will be located wrong and you'll likely get tire rub.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-09-2015, 12:25 PM   #12
vin63
vin63's Avatar
^^^ This is why I modified and sectioned the sheet metal/bed side. Physically moving the axle centerline back (either by moving the trailing arm cross member, extending the trailing arms, etc.) involves a lot more engineering consideration and structural work.
Old 04-09-2015, 05:32 PM   #13
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
what about stepsides? it seems to me that the axle sits about 2 inches too far to the rear?
on my 61 short step the tire is centered similar to the ones in this pic.
Old 04-09-2015, 05:46 PM   #14
chevy_mike
chevy_mike's Avatar
Looking at the pics of those steppers and the fleet, it seems the wheel opening is shaped differently and is located closer to the cab. Be interesting to get a measurement between the two styles.
Old 04-09-2015, 07:06 PM   #15
Gooker928
I don't know if I'm understanding the O Ps question but I lowered my rear 4 inches and I used captainfabs brackets to add disc brakes. The brake kit widened the rear a couple inches and the lowering made the rear biased toward the passenger side about an inch.
I hooked straps up going from my driver side wheel to the frame on the passenger side.
I tightened the straps until both sides measured the same and I adjusted the panhard bar to fit and tightened. When I released the tension on the straps it was all good.
Gooker928 is offline   Reply With Quote
Old 04-10-2015, 02:52 AM   #16
Paul Y
Planning on taking the bed off in a few weeks time to repair the damage to the b pillar and front edge of the bed. Will look at the various options including moving the arches. Thak you all for your thought and experience.
P.
Old 04-10-2015, 01:00 PM   #17
DLW
Also it says:
"Note:
I used the PB level 2 kit which keeps everything lined up where it should be. I believe they are referring to the 2 piece driveshaft support bearing, I have a one piece DS.
Old 06-19-2020, 09:15 AM   #18
mookandairin
I know I havent been here for a long time (nor would anyone even remember me) and this thread is as old as I am but I am right at this spot on my build. I have a 65 step and the rear is offset in the wheel well. I am just curious as to how you adjust it straight or even if it is adjustable? I havent been under there yet but it is going to be tackled as soon as I get my turbos, boost, A/F ratios ironed out. is it as easy as measuring/adjusting or is it going to be another can of worms lol. I cant tell you how many times I have had to put them back in the can after I opened that damn can up lmao
mookandairin is offline   Reply With Quote
Old 06-19-2020, 10:14 PM   #19
Captainfab
60-66 Nut
Are you talking about offset side to said or front to back?
