#1 | |
HD rotor & LD rotor measurments
Where are these measurements taken to find out which rotors your looking at?
Is this talking about thickness or edge of the rotor? The bearing opening? Quote:
1965 C10 Project |
Never Ending Projects
Re: HD rotor & LD rotor measurments
On a new rotor, these would be the thickness of the rotor face. Now if you have used rotors, there could be enough wear that the thickness could be less than what is listed so it's not as easy. I know the bearings are different sizes but don't know those measurements off the top of my head.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Well they are used, so they must be the HD rotors. I didn't get down on the rotor. I just threw a tape on it and it was what looked like close to 1-1/2". So I would say they are definitely over 1" thick.
1965 C10 Project |
Sounds like the HD (thick) rotors.
