04-07-2015, 09:17 AM | #1 |
T5 Installed
I've been working on this alone for the past 2 weeks, not being in any hurry. After removing the 3 speed, I figured since its out, might as well replace the rear main and reseal the oil pan. I did both of these, then moved on to installing the t5.
Couldn't have done it without Jays (lugnuts65) help! BIG THANKS!!!! Keep in mind that 2 week ago I didn't even know a t5 existed lol. After reading his write up, pm'ing and some phone conversations he was able to get me through it. His t5 page can be found here and has some excellent info and pictures for anyone wanting to do this swap! http://lugnutz65chevystepside.weebly.com/ He goes into all the details on his page, so Ill just hit a few highlights of my swap. Once the input shaft was changed and cut down it was time to measure the driveshaft length. A driveshaft shop would frown upon doing this but I have cut a few drive shafts down over the years and never had any issue. I measured, cut and welded the driveshaft back to the length it need to be, replacing the ujoints while I had it out. Once the t5 was in place, I measured for the shift hole in the floor. My advice, cut a little, measure a lot and you'll do just fine! I also bent a long and high gear shifter (might take some out of it, but I dig the high and long look). Still waiting on my 8ball shift knob to arrive.
My Jalopy - http://67-72chevytrucks.com/vboard/s...d.php?t=641102 Last edited by SayBye; 04-07-2015 at 09:24 AM. |
04-07-2015, 09:19 AM | #2 |
Re: T5 Installed
The ebrake crossmember has to be removed to get the t5 in place. I drilled the factory rivets out. Once t5 was in place, I moved the crossmember under the frame and made some spacers, bolting it back to the frame.
My Jalopy - http://67-72chevytrucks.com/vboard/s...d.php?t=641102 |
04-07-2015, 09:21 AM | #3 |
Re: T5 Installed
As I said my gear shifter is huge but I dig the look. Prolly will end up cutting it down some more but we will see...
04-07-2015, 09:27 AM | #4 |
Re: T5 Installed
Got the fluid top'd off last night but didn't get to take it for a spin. Cant wait to get off work and take it down the road! I did pull it forward about 10ft then back up in my garage, lol felt good!
04-07-2015, 11:50 AM | #5 |
Re: T5 Installed
Sweet! Look forward to seeing how you like the T5.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-07-2015, 12:07 PM | #6 |
Re: T5 Installed
Nice work and looking good! You'll love that T5, it makes a huge difference! Just make sure you get that driveshaft balanced, mine wasn't and I was chasing down vibrations in all gears for a while until I had it rebalanced.
04-07-2015, 09:11 PM | #7 |
Re: T5 Installed
Man that's sweet ... Nice job
04-07-2015, 09:44 PM | #8 |
Re: T5 Installed
I'm grinning cause he did the Jeep shaft swap too! Awesome!
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
04-07-2015, 09:47 PM | #9 |
Re: T5 Installed
Took it to the gas station today and around town for a minute, drove great! Absolutely love the t5! Highly recommend for anyone looking to get away from the column shift.
04-07-2015, 09:55 PM | #10 |
Re: T5 Installed
How does 1st gear feel? I think yours is a 3.97 IIRC? Anyway, you will probably like the little extra jump off the line when the light turns green.
04-07-2015, 09:58 PM | #11 | |
Re: T5 Installed
Although, I fear my rear main seal swap was a waste of time
04-07-2015, 10:02 PM | #12 |
Re: T5 Installed
If you have a tach, look to see what your RPMs are next time you do 65 MPH. That info along with the tire diameter too. You said your diff was 3.73, so I'm thinking you are turning around 2100 RPMs at 65 MPH. Or close to it.
04-07-2015, 11:41 PM | #13 |
Re: T5 Installed
I am currently working on this install myself. The information from LugNutz65 is great and very accurate! Glad to see someone else finish this - keeps me going!
04-08-2015, 06:53 AM | #14 |
Re: T5 Installed
Great to hear! Like I said it took me, by myself, about two weeks working on it a few hours a night Monday through Thursday. Keep at it, its a sweet reward!
04-08-2015, 10:54 AM | #15 |
Re: T5 Installed
i went to look at a 65 with a 350 w/T5 near st.louis
it drove great but the guy wanted way too much for his junk truck. |
04-08-2015, 11:56 AM | #16 |
Re: T5 Installed
Glad yer happy with the T5. You'll notice some better mileage as well. I'm doing a TKO600 for my hopped up 292...Bang shifting time! lol
04-08-2015, 07:54 PM | #17 |
Re: T5 Installed
You can put the rear view mirror on top of the shifter as tall as it is. Just put pistol grips on the shifter were your hand natural fits.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
04-08-2015, 08:01 PM | #18 |
Re: T5 Installed
Nice job!
It only has original paint once |
04-08-2015, 08:17 PM | #19 |
Re: T5 Installed
That's right. I like it though, actually took about 2" outta it tonight and put an 8 ball on it. No leaning up, no unatural reach, just throw ur hand up and it's there
04-08-2015, 08:19 PM | #20 |
Re: T5 Installed
Need a go pro shot of you cruising it.
04-08-2015, 11:45 PM | #21 |
Re: T5 Installed
Ended up taking more out of it after a few beers. Haven't driven it yet, kinda nervous that it won't feel as good as the higher version...
04-08-2015, 11:47 PM | #22 |
Re: T5 Installed
One more. Will update tomorrow on the feel of things...
04-08-2015, 11:49 PM | #23 |
Re: T5 Installed
Looking for a factory radio to fill the void if anyone has one laying around, working or not working, just need one for looks. iPod setup going in the glove box...
04-09-2015, 08:20 AM | #24 |
Re: T5 Installed
Looks great... I know one thing for sure Jay (lugnutz65) is passionate about T5's and more than willing to give some great advice when it comes to them. Hopefully I can be that helpful to someone else on the board one of these days!
04-13-2015, 08:15 AM | #25 |
Re: T5 Installed
My engine and tranny are at the shop. I'll be using a 235 with the T5 behind it and I cant wait.
