Old 04-07-2015, 11:44 AM   #1
Hair
Best Engine Rebuild Kit?
1989 350 - who sells the best quality engine rebuild re-ring kit?
Hair is offline   Reply With Quote
Old 04-07-2015, 07:23 PM   #2
Tom
driving is in my blood
Tom's Avatar
Re: Best Engine Rebuild Kit?
rebuild and re-ring are two completely different things, which are you doing?
Old 04-08-2015, 09:19 AM   #3
Hair
My bad, I'm sorry - rebuild kit- it will be bored. New bearings, pistons, rings, gaskets, oil pump, timing chain... I plan on buying the cam and lifters separate so I think that's a "rebuild " kit. a "master rebuild kit" comes with cam and lifters... I reckon that's how it works.
I've been looking at the premium rebuild kits from Summit with Federal Mogul gaskets and Sealed Power pistons for about $350... is something like that the way to go?
In the past, I've used generic economic rebuild kits, but I just rebuilt two of the same Toyota engines for friends & family, one with generic parts and the other with all Toyota parts and high quality bearings, rings and pistons. After about 30k I can tell a difference in the two. After 40 years, I'm starting to think that maybe you do get what you pay for
So now I'm back at home with a Chevy and I'm thinking maybe the same principal applies? Should I go with all GM parts? Is the Summit kit better, is there something better out there? What do you guys use?... That's where I'm at. That's why I'm asking.
Old 04-08-2015, 11:25 AM   #4
iluvmy72
I would hit the local rod shops in your area.....they might be able to help more
iluvmy72 is offline   Reply With Quote
Old 04-09-2015, 07:08 AM   #5
BigBlocksRule
^ yep, give the shop that's doing the machine work a shot at it. If they're way out of line with their estimate, either Summit or Northern. Look for Clevite bearings and moly coated rings, plasma moly is best.
BigBlocksRule is offline   Reply With Quote
Old 04-09-2015, 04:08 PM   #6
Tom
Tom's Avatar
I would go to the machine shop with the stuff you want and how much you can get it for, give them a chance to match or at least come close. If they aren't off by much then buying from them usually means a little more love in your machine work by them
If not, the premium kits from summit are a really good value IMO, I've used one before on a 5.0 ford.
Old 04-10-2015, 07:04 AM   #7
BigBlocksRule
That's been my exact experience - you're either a guy having machine work done or you're a customer.
