Old 04-07-2015, 08:56 PM   #1
Russ_the_truck79
ELECTRICAL DEMON! I'm stumped
so about a month ago I pulled up to a stop sign and took a right the truck just died... the only thing that worked was the left turn signal which i didn't even turn on! I took the key out and fiddled with the turn signal switch but the thing kept blinking! nothing else worked the truck would not turn over or make an electrical clicking noise or anything, even the seat belt buzzer didn't have enough power to make a noise. All connections were good as far as I knew. (I tightened up the battery to starter connection the night before as it was loose+no fuses were melted) Had to pop start it and I drove home (about 20 miles and plenty of stop signs) no problem...
I haven't had anymore problems since until last night when I shut my truck off at the drive through window. The truck was warmed up and the gauge said the battery had good voltage but the truck could only turn over once and very very slowly when I attempted to start it not 2 minutes later! Since this is my dd I am very hesitant to drive it now... I'm not sure if the problems are related or not but Please help!
BTW I recharged the battery after the first incident using a charger and an extra battery in a way that supposedly would refresh a battery that wasn't truly charged The charger said it was fully charged but it couldn't turn the engine over. After using that special charging method the battery worked and continued to work very well.
Thanks for reading I know that was long...
could of had an air conditioned honda but,
I'm hard headed and have standards
Russ_the_truck79 is offline   Reply With Quote
Old 04-07-2015, 09:54 PM   #2
Russ_the_truck79
Re: ELECTRICAL DEMON! I'm stumped
I apologize for posting in the wrong area... it's been awhile since ill post this in the correct page
