12 Bolt Rebuild
I'm rebuilding the original 12 bolt in my 69 shortbed c10. I have a big block motor that will be used for street/strip (mainly just having fun, nothing serious) that has been dynoed at 540 hp and 550 lbs of torque. My question is this: Is what I bought enough to beef this 12 bolt up to handle that power. Here is what I have bought so far: everything listed is brand new
Alloy axles 30 spline Eaton Differential 3.73 ring and pinion Changed out bearings outter and inner New c clips New differential cover (b&M) What are yalls thoughts? |
Re: 12 Bolt Rebuild
I would suggest upgrading the internal clutch springs to the 800lb class if that's not what is in the new eaton unit. Don't overlook the brakes, takes a lot to stop that kind of power.
Re: 12 Bolt Rebuild
The parts you bought will be fine if you run street tires. Even on sticky tires at the track they should be OK. Just don't let it wheel hop...
Re: 12 Bolt Rebuild
Did forget to mention, I did upgrade to disc brakes on all 4 corners.
Re: 12 Bolt Rebuild
Awesome, thanks for the input. This definitely helps!
![]() Join Date: Feb 2001
Re: 12 Bolt Rebuild
That's a lot of hp... should be fun
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Re: 12 Bolt Rebuild
Yeah, you'll be fine with that.
#8 | |
Still plays with trucks
Re: 12 Bolt Rebuild
The cost is about the same either way once you pay to have the housing ends installed but you can put the C-clip eliminators on yourself at home so that factor comes into play. I broke a 30-spline aftermarket axle with slicks on my 70 Chevelle with a similar power output 454. The C-clip eliminators I put on kept the wheel from coming off. For the piece of mind it is not that much extra money added to what you have already invested. Depending upon the way your caliper brackets mount you may not be able to run C-clip eliminators without modifying the brackets to mount from the back of the backing plate mount flange instead of the front like most disc conversion parts I have seen are done. The press-on bearings will also make your axles last longer as the axle is no longer the inner bearing race and prone to wear as with stock style wheel bearings.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
