Old 04-07-2015, 09:51 PM   #1
SayBye
SayBye's Avatar
Removing front bumpstop brackets?
Cut my springs a while back and removed the rubber bumpstops but left the mounting bracket still intact. Now I've decided I'm not low enough in the front so I'm wanting to completely remove them and cut some more out of my springs. Right now I sit about 1/2 above them, and bottom out regularly. Any pics of ur factory control arms with the bump brackets removed? Just trying to get any idea of clearance before I start...
SayBye is offline   Reply With Quote
Old 04-08-2015, 07:00 AM   #2
SayBye
SayBye's Avatar
Re: Removing front bumpstop brackets?
I think I just answered my own question...
http://67-72chevytrucks.com/vboard/s...d.php?t=562231
If anyone has any input feel free to post!
Im hoping I can get a grinder in there without have to take the ball joint loose....
Old 04-08-2015, 11:08 AM   #3
earl84
I cut mine off, leaving enough to have a steering stop. I need to look into bump stops, but not high on my list right now. I was bottoming with 2 inch lowering springs, rides better now. Also added shock extender and new KYB shocks, rides way better. You can get a Sawzall in easily. Grinder has some limitations, but you can make it work.
earl84 is offline   Reply With Quote
Old 04-08-2015, 11:51 AM   #4
Ratpin
Ratpin's Avatar
How much have you cut out of your spring?
"It ain't as easy as Chip Foose makes it look"
Ratpin is offline   Reply With Quote
Old 04-08-2015, 12:13 PM   #5
SayBye
SayBye's Avatar
I believe if my memory is correct I have cut out 1.5 coil outta the front. I think...
With the rubber part of the bump removed, Im sitting about an inch over the bracket...
