04-07-2015, 10:05 PM | #1 |
Can i put a 5.3L/4l60E trans into a low hump cab
I am replacing my cab on my truck and may have a line on a great cab, but it might be a low hump cab, is it possible to do the swap with the low hump cab, or will I have to install the higher hump panel in.
04-08-2015, 12:14 AM | #2 |
Re: Can i put a 5.3L/4l60E trans into a low hump cab
Yes, it fits great. Im doing it with a panel now
04-08-2015, 12:22 AM | #3 |
It's Better With Nitro
I installed a 4L80E in mine without a problem.
04-08-2015, 12:26 AM | #4 |
excellent
04-08-2015, 07:43 AM | #5 |
What about a 700r4? If you don't mind me asking in your thread..
04-08-2015, 08:30 AM | #6 |
1965 Chevy C10, 2005 4.8L/4l60
700r4 and the 4l60/4l60e are kissing cousins, basically the same trans.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-08-2015, 12:42 PM | #7 |
Should be no problem. If your doing/going to do a level 3 PB drop member might be a different story. Either way converting to a high hump later is not that hard.
