Old 08-29-2003, 04:58 PM   #1
jamie72
jamie72's Avatar
Question measurement for a swb with blazer tank...
could someone with a blazer tank installed in there truck give me the measurment from the back of the frame to the filler neck,looks like its going to hit on the bed cross sill.
i just need to know how far up to move it.
thanks all
jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 08-30-2003, 05:22 AM   #2
Mudder
Mudder's Avatar
I think it does hit most of the ones I have heard of. I cut most of my cross sill away on the drivers side.
Mudder is offline   Reply With Quote
Old 08-30-2003, 05:33 AM   #3
67cst
i love summertime
67cst's Avatar
yep, mine hit
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 08-30-2003, 10:01 AM   #4
72MARIO
72MARIO's Avatar
You can heat the filler neck up with a heat gun. Put a socket and exstion around the neck and heat the base of the filler neck when it get's warm enough pull gentally in the direction you want the neck to go.(most likely back)
Allow the neck to cool while you are holding it in place.
I did this to my tank and it worked perfect.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-31-2003, 09:26 PM   #5
jamie72
jamie72's Avatar
i was hoping to just move it forward a little to clear the cross sill.
i got a poly tank so i think i won`t be able to turn the neck...
thanks guys
jamie
jamie72
member #807
www.antlertalk.com
