Old 04-08-2015, 08:07 AM   #1
70c10guy
Help!!
Hi everyone. I've got a huge oil leak around my pan so I thougt it was the oil pan gasket. Replaced the gasket with felpros one piece and it worked like a charm. The engine has been dry for a couple of days now but this morning when I checked... The passenger side wheel housing was covered in oil. Now my valve cover gaskets are new as well so I didn't think it would come from there... The only thing I can think of is head gasket? I don't smoke at all though!! I don't get it.
70c10guy is offline   Reply With Quote
Old 04-08-2015, 08:25 AM   #2
Sklptrljay
Sklptrljay's Avatar
Re: Help!!
Possibly from your dipstick. Did you maybe forget to put it back in when you did the pan gasket?
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 04-08-2015, 08:33 AM   #3
70c10guy
Re: Help!!
Nope, dipstick is on the driver side! I'm lost At this one.
Old 04-08-2015, 08:39 AM   #4
Steve-W
Steve-W's Avatar
Re: Help!!
you forgot the bottle of oil and it spilled? probably fell under the car while driving?
you sure it's engine oil btw?
Feedback is always welcome!
projects:
1969 Chevy C10
1950 GMC 100
1958 Chevy C60 Viking ratrod
Steve-W is offline   Reply With Quote
Old 04-08-2015, 08:48 AM   #5
70c10guy
Re: Help!!
Lol, but yes definitely oil!
Old 04-08-2015, 09:03 AM   #6
68 TT
Still plays with trucks
68 TT's Avatar
Re: Help!!
The back of the intake manifold is famous for blowing out on older engines due to the increased crank case pressure from mileage wear & tear on the rings.
They are also easy to push out of place slightly when changing the intake gaskets if you are not careful which leaves them more vulnerable to push out from even normal crank case pressure.
It causes a pretty good oil leak and is tough to see well enough to tell where the oil is coming from.
I have also seen where a piece of the wire harness or a plug wire got wedged under the back of a valve cover during installation of new gaskets and kept the valve cover from being seated all the way. Might want to check for that on the passenger side to make sure it didn't happen to you.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 04-08-2015, 09:05 AM   #7
70c10guy
Re: Help!!
Valve cover is clamped down good, Intake isn't leaking as well! It was all sealed up and dry but the oil just came out of nowhere after two days of a dry engine bay!
Old 04-08-2015, 09:20 AM   #8
sboris
sboris's Avatar
Re: Help!!
There is such a thing as over tightening. Double check the pan and valve covers. It can distort the metal to where you will never get it to seal.
Go over it with a fine tooth comb. Wipe it or clean it up, start it up, crawl all over it with a light.
Check the oil sender behind the intake if ya have it. Get a mirror for that. Intake in the same area.
Is it on top, or under the wheel housing? Im betting something you just fixed let loose..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 04-08-2015, 09:41 AM   #9
70c10guy
Re: Help!!
Well I used the gasket with the metal cores in the holes. I'll give it a woo and check it out!
Old 04-08-2015, 09:46 AM   #10
motorcritter
motorcritter's Avatar
Re: Help!!
Clean everything thoroughly, use a flourescent dye, and spot the actual source. Squashed valve cover gaskets are a tricky one, and that rear intake manifold seal can be a sneaky headache. We used to solve oil leaks, in my old shop, like that. It could take a couple days to spot them, but, customers were happy to pay for the service. Those HOA rules about dirty driveways motivated them greatly.
If 'that which does not kill me, makes me stronger', then I should be Superman by now!
motorcritter is offline   Reply With Quote
Old 04-08-2015, 09:55 AM   #11
70c10guy
Re: Help!!
I'll give it a try! Thanks everyone, is it possible it's coming from the head gasket though? It looks like the source is Inbetween #2 and #4 cylinder by the plugs.
Old 04-08-2015, 10:48 AM   #12
motorcritter
Re: Help!!
Off-hand chance of wicking up around head bolts, but that wouldn't be substantial. Head gasket can leak externally, you may have bigger problems afoot.
Old 04-08-2015, 12:00 PM   #13
70c10guy
Re: Help!!
Uh oh. I guess we will see!
Old 04-08-2015, 03:21 PM   #14
WIDESIDE72
WIDESIDE72's Avatar
Re: Help!!
If you sealed up the pan, it found the next best place. Have you checked both gaskets under the fuel pump?
WIDESIDE72 is offline   Reply With Quote
Old 04-09-2015, 04:17 AM   #15
MikeyMan
Re: Help!!
x2 on the fuel pump.
MikeyMan is offline   Reply With Quote
