Old 04-08-2015, 04:12 PM   #1
1moretoy
Shock relocators need help ASAP.
Who you guys recommended? Ece, cpp or No limit. No limits look good but looks like there could be some clearance issues with running wide rims and they are double the price of ece and cpp. Truck is bagged with 2" drop blocks and a c-notch. Will cpp or ece get me to the desired shock angle with bags?
Thanks,
1moretoy is offline   Reply With Quote
Old 04-08-2015, 04:27 PM   #2
SCOTI
SCOTI's Avatar
Re: Shock relocators need help ASAP.
Specifically..... Front? Rear? Both? Rear suspension type?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-08-2015, 04:38 PM   #3
1moretoy
Rear and bags with a c-notch and 2" lowering blocks.
Old 04-08-2015, 05:14 PM   #4
shawno72
C/10 junkie
shawno72's Avatar
Never had a problem with CPP or ECE and I've used both
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 04-09-2015, 01:19 PM   #5
1moretoy
Have any Kyb part numbers for bags and a c-notch? Front and rear.
Old 04-09-2015, 01:44 PM   #6
71swb4x4
71swb4x4's Avatar
ECE. Great parts, great customer service.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-09-2015, 02:13 PM   #7
SCOTI
SCOTI's Avatar
Or DYI . . .....
http://67-72chevytrucks.com/vboard/s...d.php?t=451200
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-20-2016, 04:39 PM   #8
ck5566
AS for ECE go's 2X's and for CPP 0X's, that's right you seen a zero (0) not a mistake. Read more post's and you will see how much Bad comments about CPP from other members here. This is only my opinion and you will have to make up your own mind on them.
ck5566 is offline   Reply With Quote
Old 08-20-2016, 11:44 PM   #9
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I have used both. The are about the same but my preference is ECE. Just a little nicer.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
