Old 04-08-2015, 04:34 PM   #1
davepl
davepl's Avatar
What is the "right" amount of vacuum for a stock motor?
My 402, which we rebuilt entirely stock except for the cam (bear with me), maxes out at just under 15" of vacuum at idle in neutral around 650 rpm. That's more than enough for brakes and so on, but I want to know if I've got it close to stock.
The cam is supposed to be as close as we could get to the 310hp cam. It's 214/218 (110 degree intake center, 66 degrees overlap).
I want it to run "like new", not a little better than new. It did pull 323 on the engine dyno vs a rated 310 so it's darn close. That was probably with headers, but that's probably how they rated them gross in 1970 anyway.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-08-2015, 07:11 PM   #2
jocko
jocko's Avatar
Re: What is the "right" amount of vacuum for a stock motor?
Dave, the number I had in my head was 16" minimum is what was required to fully operate a brake booster, etc. 15 will work fine, I'm sure, but just thought I'd relay. Am interested to hear what others think on this one also.
