Old 04-08-2015, 07:04 PM   #1
Greg63
Enjoy your truck
Greg63's Avatar
Clutch rod - pedal to bell crank
Is anyone reproducing the clutch rod that goes from the cab, through the firewall, to the bell crank (z-bar)? Every rod I see or find is worn out from years of pivoting with no lubrication.
Greg.
1 Corinthians 10:13
1963 Chevrolet 1/2 ton
2010 Camaro SS/RS
2014 Jeep Grand Cherokee
2016 Jeep Cherokee
Greg63 is offline   Reply With Quote
Old 04-08-2015, 09:23 PM   #2
pimpston65
pimpston65's Avatar
Re: Clutch rod - pedal to bell crank
Greg.
talk about worn out!!! i been looking for an oem piece, no luck so ima prep and build weld the ends and file to shape it!!!
pimpston65 is offline   Reply With Quote
Old 04-08-2015, 09:32 PM   #3
Greg63
Enjoy your truck
Greg63's Avatar
Mine looks just like that - maybe a little more worn, but only on one end.
Greg.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 04-08-2015, 10:55 PM   #4
Lugnutz65
Lugnutz65's Avatar
Greg.
Truck and Car Shop (shops in Orange, CA & Charlotte, NC) has the upper rod listed for 67-72 and from everything I've read, the upper rod is the same as 1963-66. If the length is different and it doesn't work, then I'd recommend upgrading to the heim joint style conversion. LMC sells it.
Link
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 04-09-2015, 12:02 AM   #5
padresag
$100.00 and you will be in business. check this out
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=89
bottom of page
or you can find the ends and make your own
ron
padresag is offline   Reply With Quote
Old 04-09-2015, 03:25 AM   #6
jtrichard
Braze it up and file it round again is what i would do ...last another 50+ years
jtrichard is offline   Reply With Quote
Old 04-09-2015, 06:27 AM   #7
Greg63
Enjoy your truck
Greg63's Avatar
bottom of page
ron
I actually did make my own with a pair of those joints, sources locally, and the rod worked pretty good. The problem now is that I just replaced my headers with another brand/style and there is now no room for the bolt that holds the rod to the z-bar.
$100 is pretty steep. I used my existing rod, cut the ends off and threaded it. The joints were about $8 each.
Greg
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 04-09-2015, 06:28 AM   #8
Greg63
Enjoy your truck
Greg63's Avatar
I thought about that but wasn't sure that the braze would be as strong as the hardened material the rod is made of.
Greg.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 04-09-2015, 08:36 AM   #9
1963c-10
1963c-10's Avatar
I may have an extra you can have Greg...let me look tonight. The stepside was converted to hydraulic clutch and I converted the fleetside to an auto, so I have at least one sitting around as I know one was sent to another member. I'll let you know once I get out there tonight.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-09-2015, 10:38 AM   #10
chevy_mike
Never Ending Projects
chevy_mike's Avatar
I have had the same problem. I used my MIG welder to fill up the area and ground it back to shape. Worked great. Though I haven't used the hiem joint setup on a truck, I did use a similar setup on a '69 Camaro and it worked awesome. Everything seemed so much smoother in operation with the hiems.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-09-2015, 01:49 PM   #11
jtrichard
Greg.
I have found that the brass generally works better than original as it is a dissimilar metal and therefor acts like a bearing
Old 04-09-2015, 02:32 PM   #12
Greg63
Enjoy your truck
Greg63's Avatar
I liked the smooth operation of the hiem ends but there is now no room for the one end.
Greg.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 04-09-2015, 02:32 PM   #13
Greg63
Enjoy your truck
Greg63's Avatar
Thanks - I appreciate your offer.
Greg.
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 04-09-2015, 02:48 PM   #14
padresag
Greg
I thought that it was expensive to and that is why I suggested the ends and make your own
ron
Old 04-09-2015, 02:52 PM   #15
padresag
the holes are usually worn to and it is easy to just bore them out and insert a brass bushing. so instead of brazing , hard weld instead and clean up the end
ron
Old 04-10-2015, 10:26 AM   #16
1963c-10
1963c-10's Avatar
Greg.
Didn't have time to make it out to the tool shed last night Greg. Will definitely get out there tonight.
Old 04-13-2015, 09:14 AM   #17
1963c-10
1963c-10's Avatar
Found the one I have Greg. Looks like the one in Post 2 as far as wear. Its your if you want it though.
Old 04-13-2015, 09:55 AM   #18
pimpston65
pimpston65's Avatar
Found the one I have Greg. Looks like the one in Post 2. Its your if you want it though.
i sure hope he doesnt, cuz i need one also... if not i'll weld and file mine into submission!!!
Old 04-13-2015, 10:03 AM   #19
1963c-10
1963c-10's Avatar
If Greg decides to pass on it, its yours pimpston65. Still have those 63 door plugs to send you also.
Old 04-13-2015, 10:15 AM   #20
pimpston65
pimpston65's Avatar
nice, after you get that bed painted!!!
Old 04-13-2015, 10:35 AM   #21
1963c-10
1963c-10's Avatar
haha....yeah. Bed still needs done. May or may not be after I get it running. Still waiting to see how the timeline plays out.
Old 04-13-2015, 02:43 PM   #22
Greg63
Enjoy your truck
Greg63's Avatar
Thanks for checking but I will pass. Looks like it will go to Michigan.
Greg
1 Corinthians 10:13
2010 Camaro SS/RS
2016 Jeep Cherokee
Old 04-13-2015, 03:00 PM   #23
1963c-10
1963c-10's Avatar
No problem Greg. Was worth a shot anyway though. I'll get it mailed out to you then Eugene.
