04-08-2015, 09:10 PM | #1 |
speedo help
Hooked up my dolphin gauges but my speedo off the computer at idle not moving it pegs at 145 mphs and moving at 20 mph 8ve followed the calibration steps hasnt helped have not called dolphin yet do i need to tap off the vss at the transmission?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-09-2015, 01:05 AM | #2 |
meowMEOWmeowMEOW
Re: speedo help
What input does it want? The vss is a 4k signal I belive, if the gauges expect different, it won't read properly.
Certain changes can be made in the tune as well if the gauges don't have variable input.
04-09-2015, 08:02 AM | #3 |
Re: speedo help
i do not know whqat the gauge wants as its not in the book and there customer support is not that great, right now i have it hooked to the computer wire and it wont read pegs 145 not moving and sit at 20 moving off the computer wire, i've done the calbartion the book says but it did not help
04-09-2015, 08:24 AM | #4 |
Old member
Re: speedo help
04-09-2015, 08:34 AM | #5 |
Re: speedo help
Thats the book i have
04-09-2015, 09:07 AM | #6 |
Old member
Re: speedo help
I found this to. Maybe it will help. They have no tech support at all on the website which would bother me if I had their product.
http://www.alanhorvath.com/54chevy/dolphingauges.php This is a link off the post. http://www.alanhorvath.com/54chevy/c...o_adjust_4.jpg This is why I went with www.speedhut.com GPS no calibration.
04-09-2015, 09:10 AM | #7 |
Re: speedo help
those dont help as mine is the one touch speedo it doesn't have the pin switches
04-09-2015, 06:13 PM | #8 |
meowMEOWmeowMEOW
Re: speedo help
Did you look at this one?
http://static.speedwaymotors.com/pdf/910-97710.pdf They have some explantation on how the pulse signal is made. Its a bit confusing but it looks like which wire is hooked up determies the rating. I see 4,8,16k pulses being possible if I read this right. Otherwise in the "speedometer" tab in HP Tuners you can alter the VSS output signal to 8 or 16 to match the gauges. Whoever did your tune should be able to make this change in about 28 seconds if his fingers are all broken.
04-09-2015, 06:38 PM | #9 |
Re: speedo help
Ill look at it problem is tune was a mail oder tune
