04-08-2015, 10:56 PM | #1 |
Lowering shocks on an '81 C-10 (2" lowered)
Lowered the front of my truck 5" overall. 3" with drop spindles and 2" drop springs, shortening the travel basically 2".
So now I need to get some shorter shocks. What have you used to give better ride quality and have no issues with bottoming out on the travel. |
04-09-2015, 05:57 AM | #2 |
Diggin The SquareLife
Re: Lowering shocks on an '81 C-10 (2" lowered)
I have some belltech shocks when my truck was dropped 5/7
04-09-2015, 12:42 PM | #3 |
djm from summit racing on mine
04-10-2015, 12:33 AM | #4 |
Theoretically, if you don't trim the bump stops, you aren't compressing the shocks any further than they would have before the springs, so I don't think it would matter.
I ran 3" spindles and stock 1/2-ton coils with 3/4 of a coil removed, and then switched to 1-ton coils with 1 coil removed, and neither setup had a problem with stock-length shocks with factory bumpstops.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
04-10-2015, 08:32 AM | #5 |
When buying front shocks don't count the 3" for the spindle. You only need a shock for the 2" drop. You will need to trim bump stops but leave about 3/4"-1" to absorb the movement. You should have a good ride from this
04-10-2015, 10:57 AM | #6 |
Instead of trimming the bumpstops - drill a series of holes in them. This softens them, which means you will contact them at bump, but they "firm up" a bit more progressively, allowing you to ride lower and still ride nice (less harsh bottoming).
