Old 04-09-2015, 12:29 AM   #1
likaroc13
Rollin' Old Skool
Engine cooling system service
I'm gonna have the water pump changed on my Tahoe, & I'm curious if there's anything else (t-stat, temp sensor, etc.) that might be recommended to replace as preventative maintenance during the process? I plan to get a new lower radiator hose, which I know it could use. I don't currently have any cooling issues, so I'm a bit hesitant to mess with much. I know some folks say if it ain't broke, don't fix it. What say you?
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 04-09-2015, 10:29 AM   #2
iluvmy72
Re: Engine cooling system service
has anyone here gone to the waterless cooling. I hear it's like 300 bucks a gallon but it's well worth it. No pressurization.
iluvmy72 is offline   Reply With Quote
Old 04-09-2015, 10:35 AM   #3
54 jimmy
54 jimmy's Avatar
did mine last summer. i just drained it, flushed itout with water. till i got it to run clear. then refilled it with the green stuff. that dexcool is junk. you can change the stat if you want i didn't.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 04-09-2015, 11:27 AM   #4
likaroc13
Rollin' Old Skool
Saw a video link via another forum where Jay Leno's Garage was showing/explaining it. Pretty neat stuff.
Thanks. Yeah, the PO already switched mine over to the green stuff.
I guess I should mention, this is my second year of ownership. I've changed other parts of the belt drive system, but I'm unaware of when/if any other parts (related to cooling) may have been replaced.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 04-09-2015, 01:38 PM   #5
iluvmy72
careful gents.......switching from Dexcool will most likely blow your intake gasket if your have a 5.7 vortec. The Dexcool does work but you have to flush every 40 thousand miles. If you went to green....my condolences.
Old 04-09-2015, 01:58 PM   #6
54 jimmy
54 jimmy's Avatar
i just did intake gaskets because they were done sometime before i bought the truck. dexcool is bad for any engine. it eats the motor from the inside out with corrosion. i know gm techs that told me to get that junk out a soon as possible. i did gaskets because whoever did them before didn't replace the manifold bolts as recomended. i went with the new steel gaskets not the problematic plastic ones. i have no regrest switching. my condolences to those of you who didn't switch. dexcool is bad stuff for any engine.
Old 04-09-2015, 02:01 PM   #7
likaroc13
Rollin' Old Skool
The PO replaced gaskets on mine when he bought it. It's a commonly known problem. No issues with the green stuff in mine now. Also ran it in my '93 which had leaky intake gasket replaced. Green went back into it & was run for MANY thousands more miles with that engine, & it was just fine when I sold it.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 04-11-2015, 12:43 AM   #8
likaroc13
Rollin' Old Skool
For those of you who have replaced water pumps, I'm just curious what brand you replaced with? I'm looking at the OE equivalent Delco #89060527 or #251-719. It's a pricier option, but I don't want an el-cheapo.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 04-11-2015, 05:02 PM   #9
Mr_Rich
Mr_Rich's Avatar
I like Edelbrock water pumps. The last one lasted forever; or at least until I swapped it out to the next engine I installed. It was on there maybe twenty years before I replaced it with another Edelbrock water pump.
1989 K1500 Chev. EC
Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit.
2009 Hummer H3T 3.7L 5M (sold)
1997 K2500 Chev. EC 7.4L/ 4L80E (sold)
2018 Dodge Ram 2500 HD R/C
Mr_Rich is offline   Reply With Quote
Old 04-11-2015, 05:07 PM   #10
Mr_Rich
Mr_Rich's Avatar
The pic above was the old water pump. This is a pic of the new water pump. It has a plug on top and uses metric threads on the pulley. I used metric studs in place of bolts to secure the wp pulley.
1989 K1500 Chev. EC
Old 04-11-2015, 11:15 PM   #11
likaroc13
Rollin' Old Skool
I have a '97 Vortec 350, & I don't see an option for those from Edelbrock.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 04-13-2015, 01:33 PM   #12
likaroc13
Rollin' Old Skool
Any of you guys tried these hose clamps?
http://www.gates.com/products/automo...grip-sb-clamps
Phillip
My Build threads:
Pics:
Previous Rides:
Old 04-14-2015, 02:25 PM   #13
green_grenade
green_grenade's Avatar
I have used that style hose clamp before. They are cool.
green_grenade is offline   Reply With Quote
Old 04-16-2015, 10:22 AM   #14
likaroc13
Rollin' Old Skool
I'm contemplating replacing the two small hoses that attach to the top of the water pump. From my research, I think I have determined that one hose is referred to as the bypass hose. It attaches just below the thermostat housing. Can you tell me if this is correct? If so, I have found it available at various auto parts retailers. As for the other hose, I can't seem to figure out a specific name or part #. I believe it's just a small length of heater hose. If you can help me confirm the identity & any necessary details about each hose, that would be greatly appreciated!
Phillip
My Build threads:
Pics:
Previous Rides:
