04-09-2015, 01:28 AM | #1 |
1964 Chevy 6 lug wheels
I need a spare tire and wheel. Are all Chevy truck 6 lug wheels the same as far as lug spacing and center hole? Will a modern aluminum wheel from a 1990's or newer truck fit?
04-09-2015, 02:10 AM | #2 |
60-66 Nut
Re: 1964 Chevy 6 lug wheels
If you get a wheel from a '69-'86 K10 pickup, Suburban or K5 Blazer or a '87-'91 V1500 Blazer or Suburban it will fit. While the '88 and up trucks and '92 and up Suburbans, Blazers and Tahoe's do have the same 6 x 5.5 wheel stud pattern, the center holes are much smaller than your truck.
04-09-2015, 10:39 AM | #3 |
Never Ending Projects
What Captainfab said.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
04-09-2015, 02:48 PM | #4 |
Thanks!
04-09-2015, 05:34 PM | #5 |
04-09-2015, 08:34 PM | #6 |
1980's Toyota 4x4s used the same 6 lug pattern and I think so did Nissan, but you probably should measure the center hole. I know I've taken aftermarket wheels for a 66 and put them on a 'Yota, but I'm not positive it works the other way around. If you're looking at a scrap yard, you're much more likely to find one of these than a 6 hole GM though.
04-09-2015, 10:06 PM | #7 |
colorado wheels bolt right up, have the correct centerbore.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
