Old 04-09-2015, 11:57 AM   #1
Andy4639
Old member
Andy4639's Avatar
Lightbulb AC/Heater motor
Has anybody ever had a AC/Heater motor rewounded to blow more air? I have been thinking about doing this. If the AC blew harder it would feel like my Tahoe does I think. My 08 Tahoe seems to blow a lot harder than my truck and it just seems not to have the air like I want in the winter time either on deforst.
And before everyone says check your system it is working fine now other than the air moving. Just curious to see what anybody has done.
This got me thinking about it.
I have speakers mounted in the dash so this particular idea want work but was thinking!
Originally Posted by MikeyMan
Tri-clops windshield defroster/defogger.
The center speaker is removed from my dash. Under the grille, I mounted one of those 4" computer cooling fans. This gives me increased air flow to the middle of the windshield, and help vent heat from the stereo.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-11-2015, 09:51 AM   #2
Wrenchbender Ret
Re: AC/Heater motor
The system on these trucks blow a lot of air when working correctly. The high blower is on a separate circuit & can fail often. There is a separate fuse & a relay in this system.
The control doors also can cause the air to be deflected.
Wrenchbender Ret is offline   Reply With Quote
Old 04-12-2015, 07:04 AM   #3
Andy4639
Old member
Andy4639's Avatar
Question Re: AC/Heater motor
As stated everything is as it should be. The system is working fine. AC is 40* on a 85* day. I just want to know if anybody has ever done a mod to a blower to make it blow harder?
